#15 |
![]() Drives: 2017 Camaro RS - V6 Join Date: Feb 2020
Forget the stripes. All Vietnam veterans are heroes in my opinion. I spent a couple of years in the Army from 1971-73 but never went overseas. Thanks for your service....
#16 |
![]() Drives: 18 ZL1 - M6 Join Date: Mar 2019
#17 |
#18 |
#19 |
#20 |
Pics above look so much better than where She'z at right now.. ![]() |
#21 |
looks great!
#22 |
#23 |
![]() ![]() ![]() ![]() Drives: 2019 ZL-1, Shadow Gray, Sold Join Date: Jan 2019
Took my stripes down to the bottom of the rear bumper.
Have my entire hood wrapped in this vinyl as well, but thinking about changing it to just the nose, like others in this post. |
#24 |
![]() ![]() Drives: 2018 ZLE (M6/hyper blue) Join Date: Nov 2015
I was actually of thinking of a very similar pattern for in front of the hood vent, but also doing above the lip angled in up to the grill (following the contours, making it much like the 1LE lip look wise). I have the wide black center stripe on the roof and hood deck, and about to put a mosaic black spoiler on, but the front still looks empty.
I think it looks pretty good. If I go this route, I won't have the thinner outside line, but I did the way you used them to align the outside part of the vent, and the wider ones with the inside. |
#25 | |
Sounds like you've got a good plan as well. As I mentioned above, adding stripes to this vehicle makes it look much better. Not that it doesn't look great to begin with. Just helps it "pop". I decided to add the red "thin" accent lines because it gives a good transition and matches the "1" in the ZL1 badge and my red brake calipers. I thought it would help tie everything together and couldn't be happier with the outcome. All in all, you can't go wrong. ![]() |
#26 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro ZL1 Coupe Join Date: May 2016
The stripes on your ZL1 look good SHE’Z 18! They really accent the color of it too! Good job!
#27 |
#28 | |
![]() Drives: 2017 ZL1, 1995 Trans Am Join Date: Jan 2017
I have the Hyper Blue with the Sunroof...I am thinking silver for mine but not sure what the thin pin stripe on either side should be?
_____________________
'17 ZL1 HBM|A10|NAV|PDR|CFW Hood|Sunroof Last edited by Canadian ZL1; 03-07-2020 at 01:36 AM. |
Thread Tools | |
