02-10-2019, 11:21 AM | #1 |
Drives: 17' Turbocharged Camaro Join Date: Jan 2019
Recall alert
Getting a recall alert. Should I take in my car for it.
02-10-2019, 11:56 AM | #2 |
Drives: 2017 Super Sport Cam. Join Date: Feb 2018
This means the 1LT Engine as in SS? I see the Corvette is listed too.
02-10-2019, 12:32 PM | #3 |
Drives: 2016 2SS Convertible Join Date: May 2012
There is a recall on the electric steering. Not a rush but you will want to get it done.
02-10-2019, 01:31 PM | #4 |
meantime,work on those arm muscles just in case...
02-10-2019, 02:44 PM | #5 |
Drives: '16 Garnet Red 1SS Join Date: Mar 2014
LT1 is the engine. 1LT, 2LT is the trim package.
'16 Camaro 1SS
'18 Miata GT Gone: '01 Camaro, '14 Camaro, '90 Miata |
02-10-2019, 09:09 PM | #6 |
Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
Hmm, as of today my 2017 SS is not showing any applicable recall per NHTSA
https://www.nhtsa.gov/recalls I'll check tomorrow. |
02-10-2019, 09:14 PM | #7 |
This used to be a TSB, I believe, and than it appears to have been escalated to a field action/campaign. N1821822760 must be the latest. Maybe they are going with a different bolt. Coated or SS.
02-11-2019, 12:59 AM | #8 |
Drives: '17 Camaro 2SS & '99 Camaro Z28 Join Date: Feb 2014
I'm about 90% sure that I am a big reason this recall finally happened.
See why: https://www.camaro6.com/forums/showthread.php?t=528765 https://www.camaro6.com/forums/showthread.php?t=533044 https://www.camaro6.com/forums/showthread.php?t=535427 Cliffnotes:
02-11-2019, 07:14 AM | #9 |
Drives: Camaro Join Date: Jan 2019
Clearly says "Remedy not available yet" which means its a stop sale for lot cars but nothing you can do yet till they find a fix.
02-12-2019, 07:46 PM | #10 |
Drives: Too many to list Join Date: Dec 2011
The fix is to replace the bolts attaching the power steering motor to the steering gear. If the bolts are corroded and can’t be replaced then the steering gear is to be replaced. Any customer that paid to have this work done is being reimbursed.
03-14-2019, 06:42 PM | #11 |
Junkie
All 2017s affected?
"Letty" Murdered out 2013 Camaro 1LE. (Old car SIM 2010 2SS/RS)
03-15-2019, 02:07 PM | #12 |
EMERALD COAST CAMAROS
Drives: None Join Date: Feb 2010
Here's what I found:
https://www.consumeraffairs.com/news...es-031519.html
03-16-2019, 10:01 PM | #13 |
Drives: 2017 Camaro 50th Anniversary 2SS Join Date: May 2016
Curious what dealership you used in Austin. I’ve been reluctant to even get a free oil change at a dealer or even take my car in since the service center kept my car for over a week to replace a cracked grill when they tried to pry off the gold bow ties. Now this recall has not hit my 50th2SS M6 as of today and my garage queen only has 2850 on the odometer since Sept’16.
50th Anniversary Edition 2SS, NFG, BLACK, M6, MRC, NPP, BLACK BOWTIES
Build Date: July 21, 2016 Production Sequence: 934 |
03-19-2019, 08:20 AM | #14 |
Drives: '18 2SS/EU (+Recaros) M6 Red Hot Join Date: Nov 2018
Does anyone have a link to the actual TSB? I would like to do this myself, I don't trust the dealer to do anything on my car.
