01-16-2019, 03:32 PM | #1 |
Drives: 2015 C7 Z06 M7 Join Date: Dec 2012
Magnuson Camaro SS 5.85 @ 120 in the 1/8 mile
Finally - it's running again after the swap to an ATI TH400 / GForce 9" IRS rear and things are looking promising.
https://youtu.be/y41941b_Xsk It's the fastest pass to date (5.85@120) for this car with only a 1.4 60ft leaving from idle and a couple of tuning issues that still need to be worked out. Can't wait to try the transbrake/2-step once we get the bugs fixed. Would love to see a 1.2-1.3 60ft from this thing! |
01-16-2019, 03:55 PM | #2 |
Man that's pretty stellar for an over weight SS Camaro with the full cage in it.
01-16-2019, 04:20 PM | #3 |
Drives: 17 SS a8 Join Date: Feb 2010
Whoa. Impressive!
best et 5.83@121 with the 5.3 http://www.camaro6.com/forums/showthread.php?t=465472 |
01-16-2019, 04:37 PM | #4 |
Can you tell me more about the 9”. Did it add any noise or vibration? Which drive shaft and did it fit well? Did you do the aluminum center section? Spool? Where did you find the best price and how much?
01-16-2019, 05:39 PM | #5 |
Its a GForce 9" and don't think its an aluminum housing but the drive shaft is and its not a spool. Converter is pretty loose so changing that soon. It should go 5.60s once everything is working. I think we'll see an 8.70 pass this year at 160 or so.
01-16-2019, 10:35 PM | #6 |
Moving out!!
2016 NFG 1SS A8
01-17-2019, 07:33 AM | #7 |
I hope my new engine package and eventually a bigger SC will put me in the 6.20's in the 1/8.
01-17-2019, 08:10 AM | #8 |
Drives: 16’ 2SS A8 HBM Procharged Join Date: Jun 2017
This is crazy fast. I absolutely love the sound of the blower too. Part of me wishes you guys found a way to do this with the A8, but I also know why going to the TH400 was a smart move. They’re bulletproof and it can just be done and over with instead of wasting time with trial and error with the A8. It just would have been cool to see though for those of us that aren’t willing to Frankenstein our car too much. Then again I guess modded is modded and if you have the money and time to do anything, then why stop.
16' 2SS A8 Hyperblue | P1SC-1, Race IC | JMS fuel pump voltage booster | Jannetty custom tune | Elite E2-X catch can | M017 Wheels
01-17-2019, 10:02 AM | #9 |
Mike did run 9.15@153 with the A8 but had to launch in 2nd gear and it finally broke the converter, the A8 was not damaged. The Maggie makes torque so quickly that it was hard to get it to leave without blowing the tires off. They did have to pull power out to get it so they could launch in 2nd gear. Obviously the tracks were not prepped on the power tour and it was very hot and slick at all the tracks and that didn't help either.
01-17-2019, 01:19 PM | #10 | |
We did use the Strange 9" aluminum carrier with 3.50 gear set and have both Strange S-Trac and Eaton Tru-Trac differentials along with the accompanying GForce axles. It was purchased directly from GForce and about 7K if I remember correctly. |
01-17-2019, 01:30 PM | #11 | |
Trying to make the ECU happy has been much more work than we would have anticipated and we are still a bit from having it right. In the pass in the video the throttle closed to 63% just after I shifted into 3rd hence only 120 MPH (it normally goes about 122). That's our next hurdle and it's continually been like this. Fix one problem, the next arises. Fortunately, along with the help of many other Tuners out there, we have been able to find ways over and around each problem. There are lots of people out there that have had input to this car, more than I can list, but thanks goes out to all of them who have helped to get it this far - I'm sure we're pretty close to finally realizing a full pass soon! |
01-17-2019, 01:46 PM | #12 |
Oppps, got some of the info wrong. Thought it was GForce rear also. Most everything else was close to right.
01-17-2019, 02:07 PM | #13 |
Have you considered switching to a Holley ecu system?
2016 NFG 1SS A8
01-17-2019, 08:57 PM | #14 |
Tactical Garage
Drives: 2016 Camaro 2SS Join Date: Nov 2016
Dang, that is moving for sure.
