04-01-2018, 10:13 AM | #15 |
Drives: FIFTY 2SS Callaway Join Date: Sep 2017
I was able to get the same setup on my 2SS with MRC. I rerouted the driver rear harness (because it did rub).
But 295/30-20s upfront and 335/30-20s on the rear will fit on a SS. I am also adding some ZL1 suspension comments and when that is done I will get an alignment and get pics up. |
04-02-2018, 07:38 PM | #16 | |
Drives: 2017 Camaro 2SS Nightfall Gray vert Join Date: Jan 2018
Magnuson Heartbeat SC - Tuned by JRE Racing 776whp/745wtq (12psi) 2018 Corvette Z06 vert- Black To be tuned by JRE Racing TBD performance |
04-02-2018, 08:29 PM | #17 |
The 1LE wheels are 20”s (ZL1 1LE wheels ar 19”s). The MPSS are more of a rounded shoulder vice a square shoulder on the Toyos. If I didn’t move the wire harness in the rear driver side it would rub. But since I moved it and pinned the fender liner back I have space. There are a few others on the forum that have doe the same and they are not rubbing. So I think I am good. I will verify once I get the suspension dialed in, get an alignment and let the care settle a bit.
04-03-2018, 01:38 PM | #18 |
Drives: 2016 ss whipple,rotofab,A8,magride Join Date: Sep 2017
i need tires as large as i can fit under a 2016 ss. i thought that 305 or 315 where the largest tire you can fit on a factory wheel. now i hear 295 in front and 335 in rear? im so damn confused. i have 600 RWHP so needless to say i would love to fit a 335 on it! but i need tires yesterday...
04-03-2018, 02:38 PM | #19 |
Drives: SS Join Date: Jan 2017
I'm currently running 1LE 20x11 +43 with a 5mm spacer to bring the offset to +38 in the rear. Paired the wheels with a 325/30/20's dunlop sport max GT. Tires clear fine but occasionally rub over huge dips but it's a minor rub but I believe thats because I'm lowered on eibach springs.
I think the PSS should fit with a 335. I dont think PSS run wide at all. Have seen a stock height 1LE with 335's and there is likely just a bit more room to squeeze a 345 if you really wanted to. |
04-03-2018, 09:25 PM | #20 |
The PSS are also a little taller so they fill the fender gap a little better with stock height suspension in the rear.
04-06-2018, 10:56 PM | #21 |
Attached is a picture of the rear wheel well. I rerouted the wire harness and add the push rivet to make sure the tire will not rub on the liner. I also took a picture to compare the width of the stock rear tires with the MPSSs.
04-06-2018, 11:14 PM | #22 |
2018 ZL1 1LE
Drives: 2018 ZL1 1LE Join Date: Aug 2017
Did the push rivet just push back the liner a little? Is this why you used one. I'm guessing you used an existing hole too.
04-07-2018, 12:33 AM | #23 |
04-07-2018, 04:42 AM | #24 |
SABIO
Can you post a pic of those rear wheels on the car. Would like to see how much sidewall there is.
04-07-2018, 01:08 PM | #25 |
Here you go. they are not the best and the car has not settled from being jacked up recently and I still need to get an alignment done.
04-07-2018, 08:24 PM | #26 |
Drives: '17 Red hot 2ss, 16 Focus RS Join Date: Aug 2015
I got 325/30/19s right now and they fit fine. I couldn't imagine going much wider but anything is possible I'm sure! The only pic I was able to get [it's dark and it's not clean:( ] before winter came back in full force!
Mrc, non lowered
"Spitfire" 427ci
2017 Red Hot 2SS// 6 Piston Brembos//Adrenaline Red Interior, Knee Pads//M6//MRC Afe Air Filter//BMR MM010 Motor Mounts, Safety Loop//Custom OTR Intake//Flex Fuel Kit//Gforce 3.5" Aluminum Driveshaft//GM 95mm TB//Katech Oil Pump, Piston Squirters//Kooks 1-7/8 LT//LT4 Fueling//Mighty Mouse Wild//Monster Clutch LT1-S Triple Disc//MSD 2-Step//Pray Performance Custom Spec Cam, Ported Holley Hi-Ram//Sikky 12" Shifter w OEM Knob Mod//Tick Level 1 Tr6060//Labor by Me//Tune By Pray Performance |
04-07-2018, 11:29 PM | #27 |
SABIO
Which Tire? Weird how that 325 looks like it is too big for a 11" wheel. Sidewall looks like it is spilling over.... could just be the pic.
04-07-2018, 11:30 PM | #28 |
SABIO
