Old 01-08-2019, 12:50 PM   #127
Turtle 2ss
TBC
Turtle 2ss's Avatar
Drives: 2017 Fifty 2ss
Keeping the stock tires on it.
2017 Fifty A8, MRC, NPP, NAV, LUM, BLK BOWTIE
Turtle 2ss is offline   Reply With Quote
Old 01-13-2019, 05:33 AM   #128
PDXSSCE
Yee-aay-ee!
PDXSSCE's Avatar
Drives: 2015 2SS/RS CV CE
I'm seeing that 9" wide +25 offset doesn't require spacers and 10" wide +25 offset does require them. What about 9.5" wide +25 offset?
Will 255 wide tires fit well with 9.5" or should they be 265 wide?
Thanks in advance.
PDXSSCE is offline   Reply With Quote
Old 02-09-2019, 01:57 AM   #129
LTwin86
LTwin86's Avatar
Drives: 2017 2LT RS
Hi, spring is coming and i plan to put new wheels on my RS. Front 8.5j et30 DIA 72.6, rear 10j et38 DIA 72.6. Looks like front will need 5 mm spacer to have a stock? And Rear end no need spacer at all, any suggestions?
Also, what is a stock DIA for Camaro?
LTwin86 is offline   Reply With Quote
Old 03-01-2019, 08:30 PM   #130
VcrusaderV
VcrusaderV's Avatar
Drives: 2018 ZL-1
Nice setup.
Lethal looks awesome. I’d say that your wheel size and ride height is perfect. It’s as good as I’ve ever seen for certain.
2010 2SS Camaro (sold)
2010 ZL 427 Camaro (sold)
2012 ZL-1 Camaro (sold)
2018 ZL-1 Camaro
VcrusaderV is offline   Reply With Quote
Old 03-09-2019, 11:30 PM   #131
Schoonie3
Drives: 2018 RS
STR 607 20x9 + 30, 20x10.5 +40. Nitto 555 275/35 and 295/35. Lowered on BC coilovers.
Schoonie3 is offline   Reply With Quote
Old 04-21-2019, 02:34 PM   #132
LTwin86
LTwin86's Avatar
Drives: 2017 2LT RS
Devine wheels 8.5 front, 12 rear. Nitto 245 40, 275 35.
Old 04-21-2019, 06:39 PM   #133
orange blaze
Red Hot SS
orange blaze's Avatar
Drives: 2017 Camaro 2SS
Rim alloy front 8.5 x 20 35 mm offset with 18 mm adapters from motor-tech sport (perfect fit) with Bridgestone potenza re980as 245/40. Rear 10 x 20 35 mm offset with 285 x 35
orange blaze is offline   Reply With Quote
Old 04-24-2019, 11:59 AM   #134
Ruffers
1st time camarien
Ruffers's Avatar
Drives: 2016 RS 2LT Convertible
guys, being a noob here, I am totally lost when it comes to rims. I have a 2016 rs vert with stock wheels and brakes. I think I have found some wheels that I really like, and I have also read in here about staggered setup. so I would really like to be able to go wider in the back. but I dont know what the offset is related to and why I would need to think about that when trying to choose new aftermarket wheels.
if someone can give a brief run over on what you need to know in order to by new aftermarket wheels that would be wikid cool.
I would imagine that the breaks limit my options, but im not sure what my boundaries are if that makes sense. Sorry to ask dumb questions, but i figure learning this from the experts is probably the beast call. Last thing i wana do is order new wheels for them only not to fit or rub. im looking for a straight swap out of my existing stock 20's.
I found these that look totally sick to me
https://www.discounttiredirect.com/b...tar-ii/p/56051
thanks in advance guys!
Be nice, Be Safe.
Ruffers is offline   Reply With Quote
Old 04-24-2019, 04:37 PM   #135
PDXSSCE
Yee-aay-ee!
PDXSSCE's Avatar
I think those are truck wheels.
The following information should be helpful:
Understanding Wheel Offset and Backspacing
Old 04-24-2019, 05:36 PM   #136
BradfordCamaro
SABIO
BradfordCamaro's Avatar
Drives: 2016 CAMARO 1SS
Easiest way to get into some wheels would be buying some of the take-offs from the wheels classified section on this forum.
They would be stock Camaro wheels, if you like the look, you could look for a set from a SS or a 1LE.
Your bolt pattern is 5x120
20x8.5 front with 25mm offset
20x9.5 with 39mm offset
This is standard SS fitment which will work on your car.
You can use this info and play with the numbers on a calculator like THIS.
I like this ONE too.
Keep the overall diameter 27" and if they get pushed out about 10-20mm that is o.k too.
Old 04-24-2019, 07:33 PM   #137
Ruffers
1st time camarien
Ruffers's Avatar
Thanks BradfordCamaro, appreciate it.
Be nice, Be Safe.
Old 04-24-2019, 07:34 PM   #138
Ruffers
1st time camarien
Ruffers's Avatar
Thanks PDXSSCE, i will have a read!
Be nice, Be Safe.
Old 04-24-2019, 07:52 PM   #139
PDXSSCE
Yee-aay-ee!
PDXSSCE's Avatar
I wish the forum had a like button.
Old 04-26-2019, 11:16 AM   #140
Ruffers
1st time camarien
Ruffers's Avatar
I found these that I really like. XD rockstar 2 rims. I can see these sizes, will the following bolt layout work?
Size: bolt pattern: backspace: offset:
20x9 5x114.30/5x127 6.18 30mm
20x10 5x127/5x139.70 4.56 -24mm
i wasnt sure how spot on the bolt pattern had to be..
They do a custom bolt pattern from what I see, but Im guessing if I had to match the numbers you posted above i would need to find someone to drill them?
here is the sizing page for ref. https://www.kmcwheels.com/product/wh...sh=matte-black
Thanks
Be nice, Be Safe.
