Roto-Fab
Old 05-14-2011, 09:50 AM   #29
Caliman93230
Caliman93230's Avatar
Drives: LS3S/C
do you provide the 427, how much to stroke the ls3 motor and are you including labor plus parts,
MODS whipple 2.9L s/c, ADM race scoop, 600 rwhp 550 wrtq, .
Caliman93230 is offline   Reply With Quote
Old 05-14-2011, 02:25 PM   #30
paul2010
paul2010's Avatar
Drives: 2012 ZL1 #1278
They do provide the 427 and all labor is included per the engine as specified on the website. You would have to call Tim Dyer at LPE to ask about stroking the LS3. I don't work there I am just a very happy customer. I attached the link to the website to show you the cost to build a very affordable bullet proof engine and there are many other options you can look at there. I believe this would be a much better option then buying an LS9.
2012 ZL1 #1278
2010 2nd Place Fastest 4 5th Gen LSX Shootout
2011 2nd Place Fastest 4 5th Gen LSX Shootout
paul2010 is offline   Reply With Quote
Old 05-14-2011, 10:17 PM   #31
G200 Pilot
G200 Pilot
G200 Pilot's Avatar
Drives: 2010 Camaro SS/RS purchased 5/2010
Hey Paul, I'm also considering a new forged short block... Have read this whole thread and see you're posting prices. Would you mind sharing the total cost on your current build?
G200 Pilot is offline   Reply With Quote
Old 05-15-2011, 09:25 PM   #32
Hess Motorsports
Drives: 2010 SS with WAY TOO MANY MODS
$12k for an engine? You realize you can make 95% the same power output from the LS3 heads. Wy are so many builders trying to get people to spend money on things the DON'T need??
Keep your LS3, port the heads, build the bottom end WITH a new crank, and leave the dry sump to the race guys to save cost. You will get an 800rwhp capable engine combo out of what you have already. Sleeve it if you want for added power range and margin of safety for high boost applications. You can easily stay under the $10K range and put the rest towards a MUCH better/safer fuel sytem to go with all the boost.
Don't forget an engine build will nickel and dime you like crazy. "Oh wait... you need a better clutch & flywheel combo now. Oh for THAT amount of power you will want stronger valve train. For THAT much boost you will need to convert to return fuel. To get it to the ground, you're gonna need a drive shaft, axles, a posi, and new tires...."
See all the places you can spend even MORE money. 800 wheel doesn't require you to convert heads or blocks. Just go with a builder you can trust and make sure they can show you previous results.
Hess Motorsports is offline   Reply With Quote
Old 05-19-2011, 10:27 AM   #33
Caliman93230
Drives: LS3S/C
New question what would be the least expensive way to forge the ls3
Old 05-19-2011, 10:38 AM   #34
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
Send a message via AIM to SSE 4 2SS Send a message via Yahoo to SSE 4 2SS
Amen on the heads... We took a set that were in the shop off a G8, LS-3, same exact casting, had them reworked and are flowing just about 390 CFM... I'm all over 800 HP with a very very conservative tune... 12 Degrees of timing, 12 lb's of boost, 11.4 AFR's, and 93 octane pump gas...and 427 cubic inches...
I spent a little more to make the bottom end bullet proof, sleeved and fully forged, and less on the heads, though they flow like crazy... Unless you plan on going into stratospheric HP numbers, why dump lots of money into heads...
Have someone else pay for it??? lol, sorry....
I bought mine directly from the builder... It's in the signature...
If the car feels like it is on rails, you are probably driving too slow. -Ross Bentley
Horsepower is how fast you hit the wall.
Torque is how far you take the wall with you.
“If everything seems under control, you're just not going fast enough.” Mario Andretti
If you can turn, you ain't going fast enough...
SSE 4 2SS is offline   Reply With Quote
Old 05-19-2011, 10:44 AM   #35
2010 SS RS
2010 SS RS's Avatar
Drives: 2010 2SS/RS IBM Black Polished
Callies Compstar will handle that power range and will run around 2600 for parts including racing bearings. But keep in mind that you will need all components to support that power range. Bolts, Gaskets, fuel delivery, Clutch, axels, posi kit, valve spring kit, push rods, timing chain etc. Probably about 13K out the door.
ls9 conversion..? probably better off buying crate and selling your current set up. but then you will still be a weak sister with only 638 crank hp so what is the point?
But I totally feel you bro. The constant worry about the other shoe dropping and losing a piston can be a real burden.
Good luck
418 Stroker, 621RWHP 648 lbs TORQUE Built by Laramie GM Auto Center Tuned by Nick at Mac Autosport. EForce SC, 2 3/4pulley,LPE dual fuel pump, JRE Twin fuel rail upgrade, posi clutch kit, RX oilcatch can and breather, Callies Compstar crankshaft and rods, Racing bearings, CP -13.8 race pistons, steel rings, Comp Cams X6 blower cam, Springs, HD timing chain and tensioner, Doug Thorley Tri Y LT headers, 89.7lb injectors, RPM rollbar, DSS1400 shafts, Simpson 5 pt harness, BMR Toe rods and trailing arms, led lights, RPM input and output shafts
2010 SS RS is offline   Reply With Quote
Old 05-19-2011, 10:47 AM   #36
GTAHVIT
Blessed
GTAHVIT's Avatar
Drives: 2013 Sonic RS MT
it seems like a short block is not a bad option... It makes sense why so many guys are going that way.
GTAHVIT is offline   Reply With Quote
Old 05-19-2011, 11:00 AM   #37
Caliman93230
Drives: LS3S/C
Good luck
Just a quote on the motor Only
Old 05-19-2011, 11:02 AM   #38
Caliman93230
Drives: LS3S/C
Old 05-19-2011, 01:31 PM   #39
Hess Motorsports
Short blocks are the easy part. Just spec out with a builder (like us ) how much power you want to make. but be realistic too. Power and price rise at about the same rate. Then figure out your LS3 head options.
Don't forget for the BIG power guys... the new Darton sleeve kit. It will be just over a $2250 option to the bottom end including machine, and installation with torque plate bore/hone. But if you want that 800+whp option, it's a must.
Old 05-21-2011, 12:52 AM   #40
VADER SS L99
VADER SS L99's Avatar
Drives: 2013 A6 GT 5.0
Why are you guys skimping on the heads in these high hp high boost builds? My question is not that of power because i know and believe a ported LS3 head will take you into crazy power numbers. My question is that of reliability. Isnt the stock LS3 head prone to lifting over every other LS based head? If your head lifts and pushes water all that bling that you just threw down on the shortblock goes BOOM!
BLK/BLK 1SS/RS Ordered 11-01-2009 Took delivery 12-22-2009. Heads/cam/converter/bolt ons. SOLD Feb 2015 to fund 6th gen LT1 SS with 8L90E.
VADER SS L99 is offline   Reply With Quote
Old 05-27-2011, 05:21 PM   #41
Hess Motorsports
Modify for 1/2" ARP head studs, MLS gaskets, and anything under 1000 wheel should be MORE than safe. And yes, we've done it
Old 05-27-2011, 06:12 PM   #42
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Exactly what he said...
The 2011+ Mustang Thread GatorBlue371 General Automotive + Other Cars Discussion 11874 08-23-2011 12:30 PM
LS9 Cam in a NA LS3 Commit and Conquer V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 15 01-04-2011 10:30 PM
Manual vs Auto GTAHVIT vs PQ... The video wars. 76z28 5th Gen Camaro SS LS LT General Discussions 443 08-26-2010 12:26 PM
LS3 vs LS9 BumbleDs Forced Induction - V8 9 10-02-2009 09:27 AM
LS3 Specs revealed: GM's 436hp Sick 6.2L LS3 TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 07-30-2009 06:02 PM
