05-06-2023, 10:36 PM | #1 |
Drives: 18 ZLE, 18 SS1LE, 16 SS, 23 ZL1 Join Date: Jan 2021
No oil in MM catch can
Had the MM catch can installed about 600 miles ago, not a drop of oil in it before I went to the track. 4 sessions on track today and still not a drop of oil. Crankcase is at the full mark on the dipstick. I would think there should be something in it. Both of my SS catch cans captured oil pretty quickly. Photos of the install:
05-07-2023, 08:50 AM | #2 |
Drives: 2017 chevy zl1,1968 camaro turbos Join Date: Jun 2021
I;D SAY YOUR LUCKY, IF THERE'S NOTHING IN IT AND IT'S HOOKED UP RIGHT, I'S BREATHING AND THE ENGINE'S PERFECT. IF THIS IS A ZL1, WELCOME TO THE CLUB. THEY ARE ASSEMBLED AT THE FACTORY BY HAND, MORE EXACT THAN A N/A MOTOR. BETTER WORKMANSHIP, BETTER RESULTS.
IT'S THAT GREAT GM FEELING! |
05-07-2023, 09:50 AM | #3 |
BanHamWatch
Drives: 21 ZL1 1LE Join Date: Jan 2021
I can see your T off the brake booster, can’t really see your connection to the pcv delete at the valley plate?
Full disclosure im not a MM fan, he makes his product look pretty but I think it’s hit or miss if his internals provide proper evacuation or allow pressure build up.
2021 ZL1 1LE
Auto |
05-07-2023, 10:11 AM | #4 |
I think his plumbing looks correct. I don't think you actually delete the PCV valve with this setup. Just put a can between valve exit and intake vacuum.
05-07-2023, 10:12 AM | #5 |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
If it's installed correctly, give it time. By the time you change your oil at 3-5k miles, you'll have some oil in it.
05-07-2023, 12:28 PM | #6 |
Drives: '86 IROC-Z '18 ZL1 Join Date: Jul 2019
That looks right OP. I had the MM wild installed on my car and took it to the track. Needless to say, I got oil EVERYWHERE. I ended up realizing I can't use the wild and need the mild with the recirculating top. Not the open / vent top.
05-07-2023, 02:26 PM | #7 | |
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
1) actually provide data about venturi suction under boost scenarios. I heard Tracy Lewis say something like 14 inHg on a Dodge in a YT comment, but I've never seen real data. 2) make their website better so you can actually order a damn E2X Ultra without having to email them. 3) don't come across as a-holes on forums.
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp
Past Rides- 2014 ZL1 M6 Red Hot | Tons of mods 2004 CTS-V M6 Silver | Many mods 1995 Corvette M6 Torch Red | A few more mods 1992 Camaro M5 White | A few mods |
05-07-2023, 06:12 PM | #8 |
Drives: 23 ZL1 Join Date: Jan 2023
My mild MM install deleted the OEM PCV. Oil is present in the catch can at 600 miles for sure.
05-07-2023, 06:56 PM | #9 | |
BanHamWatch
2021 ZL1 1LE
Auto |
05-07-2023, 08:23 PM | #10 |
05-08-2023, 12:17 AM | #11 |
Drives: 2019 ZL1 Riverside Join Date: Apr 2020
05-08-2023, 05:47 AM | #12 |
05-08-2023, 06:15 AM | #13 |
05-08-2023, 09:34 AM | #14 |
Petro-sexual
Only adding for reference:
EE 3-port here, and I usually get about 1-2 TBSP of oil per oil change (oil change by OLM time - not mileage), so about every 10-11-months or so. There's hardly enough oil film to really wipe-off by finger, but some does accumulate on the discharge side of the discharge port. So - I know a little gets by. I see up to about 15-16-psi, at WOT.
