04-13-2023, 12:31 PM | #1 |
Drives: 2023 Riverside Blue ZL1 A10 Join Date: Jan 2023
Hey Guys, thanks for all the great advice about my 2023 A10, one simple question...
A lot of you have recommended changing the rear differential fluid with the oil change at 500 miles. I have always done (in the past) my oil changes at a Chevy certified dealership with Mobil 1 full synthetic. Would a dealership be where I would get the rear differential fluid changed? Would they do that for me? And should I use OEM fluid?
04-13-2023, 01:14 PM | #2 |
Drives: 2023 2SS 1LE Join Date: May 2022
the dealership will be able to do that for you, i think it was $189.99 before taxes for me.
04-13-2023, 01:15 PM | #3 |
A dealer can and will do the rear diff fluid for you, I’d use the OEM stuff as I’ve used it myself at 500 though I did it myself. I checked if the dealer near me would do it which they confirmed they would but charge an hour of labor for the 10 minute job.
Morimoto Headlights, AWE Touring Catback, MM Catch Can, ADM V2 Reservoir, Roto-Fab, C&R Oil Cooler, 1LE Grills
04-13-2023, 02:58 PM | #4 |
Drives: 2018 Camaro ZL1 Join Date: Aug 2018
Yes, any GM dealership will do this for you. They'll do any work on a GM product but if you can do this yourself, save your money and do it yourself. And yes, use OEM. Nothing wrong with OEM and no one has had any issues using OEM fluids on a stock or even a modded car. You'll find others that say you should use something other than OEM but there is NOTHING wrong with OEM fluids for a stock or even lightly modded vehicle.
Geez. $190? Ridiculous considering it's a less than 10 minute job and the fluid costs around $16 a bottle (on Amazon) and you only need 2 bottles. |
04-13-2023, 03:15 PM | #5 |
Drives: 2023 Black ZL1 Auto Join Date: Oct 2009
I'd wait till closer to 1000 miles to change the fluid. I did mine at 500 miles and it could have gone a little longer. It's pretty easy to change if you like DIY.
I would definitely use the GM fluid. It has the right amount of slip additive in it and is what the dealer will use if they change the fluid. |
04-13-2023, 03:27 PM | #6 |
Drives: 2019 ZL1 Riverside Join Date: Apr 2020
Get it changed early (at least 1000 miles) - mine looked pretty bad at 2000 (same with my SS). Do it yourself - EASY job
I only use Amsoil Severe Gear with "slip lock" additive https://www.amsoil.com/p/slip-lock-adatb/ - I've seen the standardized tests and real world operation on many forums it is the best stuff you can buy. "Only use OEM" guys will always yell the loudest but they don't know anything about these products |
04-13-2023, 05:07 PM | #7 | |
Everyone is free to use what they want but if the OEM stuff is doing its job then why fix it? Can you tell me how many engines or transmissions or elsd's have failed in the ZL1 while using the OEM stuff (not talking about the oil pump since that can fail using any fluid)? Stock or lightly modded. Now when it comes to a very modded car then you need to use something other than OEM because now you're going outside the boundaries of what the factory tested the vehicle for. |
04-13-2023, 05:25 PM | #8 |
Drives: 2020 Rally Green ZL1-1LE Join Date: May 2020
I did my diff fluid at 500 miles for the first time and every year after. It was very contaminated at 500. At 29,000 it was only slightly dirty with maybe 10,000 miles on it.
I order all my GM fluids through Amazon, including the ULV ATF fluid.I wound up flushing 3.5 gallons through my trans for this season. I only changed out 2 gallons at about 10,000 miles before that. Engine oil? I rolled the dice and used Euro non Dexos 0W-40 Mobil 1 for daily driving for the first 20K miles and 15W-50 for track days. Now that its easier to get, I've switched to Mobil 1 Supercar 0W-40 and 5W-50. The car has been trouble free so far. |
