03-04-2021, 07:30 AM | #29 | |
Drives: Which one? Join Date: Jul 2018
I guess you haven't had a poor experience with a relatively big purchase yet. One thing that is huge for me is service after point of sale... mainly, if something isn't right, how good is a said business at resolving an issue. 1) Would I agree that from everything I have read, the Maggie 2650 is the best blower at the moment - yes. 2) Is the pricing fair - I would say yes. 3) However if they can't even take the time to answer a few, very very basic questions prior to purchase.... it makes me believe that if I was one of the few people that had an issue down the road, it would be like pulling teeth working through a resolution. I've blown too much money in mods over the years(other platforms), including having some sour experiences... which is all too common in the performance shop world.
17.2 Liters of displacement.
03-04-2021, 09:54 AM | #30 | |
Drives: 19 ZLE A10,17 SS 1LE, 16 C7R,CT5V Join Date: Feb 2017
Read through the thread. You seeem to be a fine example of a customer that might get "fired". I would suggest you take your questions to the tuner, not the vendor. |
03-04-2021, 11:33 AM | #31 |
Drives: Hyper Blue 2016 2SS 6M Join Date: Sep 2017
Magnuson doesn't seen to want to discuss anything other than their base kits. For example, I called them to ask what belt part number I needed for a particular pulley size when a serpentine belt failed and took out my blower belt. They told me they didn't know, which is difficult to believe. I ended up getting the info from Greg (Laynlo).
Baby Blue
03-04-2021, 11:35 AM | #32 | |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
11-29-2021, 01:59 PM | #33 | |
Drives: Chevy Camaro Join Date: Jul 2021
Magnuson 2650 upper and lower pulley size
My question is, How do you pick the right combination of upper and lower pulley's? Mine shipped with a 70mm and 80 mm for the upper pulley. I have the stock LT4 lower. I've been told to use an ATI Damper w/9.06 DSX or the 9.45 DSX pulley for the lower. This is my build in a nutshell. What do you think? Magnuson 2650 Super Charger CNC Ported Heads @ Strictly Performance GPI Diamond L86 Forged Standard Pistons Lunati Connecting Rods, King Rod and Main Bearings Vengeance Racing Comp Cam Stage 3 LT4 w/32%Fuel Lobe Brian Tooley Racing .660” Lift Dual Valve Springs Kit w/Titanium Retainers Vengeance Racing 3/8 Hardened Pushrods IWIS Pro Series Timing Chain CHE High Performance Trunnion Kit Comp Cams Phaser Lockout GM VVT Cam Bolt GM Crank Bolt Johnson 2110R Lifters GM lifter Trays GM MLS 6.2L Head Gaskets GM LT Exhaust Gaskets DOD Delete Plug Kit ARP Cylinder Head Stud Kit ARP Pro Series Main Stud Kit GM Front Cover Seal GM Complete LT4 Fuel System Low side pump High side pump Injectors High Pressure Fuel Line Katech 112mm Throttle Body DSX Tuning Auxiliary Low side Fuel Pump DSX Flex Fuel Kit P3 Gauges w/Ethanol Sensor, Analog Boost Sensor, LC-2 Wideband O2 Sensor, OBD 2 Splitter GM 3 Bar MAP Sensor Roto-Fab Big Gulp CPR Gen6 ZL1 Front Bumper Ice Tank Mighty Mouse Solution Catch Can “SS Wild” 1000hp NGK LTR71X Spark Plugs Speed Engineering Billet Valve Covers/Coil Relocation Monster S Triple Disc Clutch Stainless Works Headers 1 7/8 and complete 3 inch exhaust system Thanks for the help! |
11-29-2021, 02:18 PM | #34 | |
Drives: 2015 Z/28 #397 2022 ZL1 #1799 Join Date: Jul 2009
Impressive build, but I think you should be using 2" Long tubes with that kind of setup |
11-29-2021, 02:26 PM | #35 |
The headers are the least of his worries. His issue is fuel system. If he is stock compression then it's not going to like the kind of boost it will make with a 9" lower(15%) and 80mm upper on pump gas. And LT4 fueling won't be enough to run much Ethanol at all. It might squeak by with a 90mm upper on E40.
2016 NFG 1SS A8
11-29-2021, 02:26 PM | #36 |
Used to own a ZL1
Drives: '16 Z06 Join Date: Apr 2020
My setup on the LT4 is similar. I run a 90mm and 9.06 lower.
Stock LT4 fuel components with cam + low side will see you running out of fuel quickly if you try something tighter. I have meth in my setup and that's just for running 93. You probably won't be able to run e85 unless you get stronger aftermarket fuel pump and injectors. |
11-29-2021, 04:26 PM | #37 | |
Drives: 2019 ZL1 Join Date: Mar 2019
I can run 40% E on my build with my Holley low side. (400 lph)
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
11-29-2021, 04:49 PM | #38 |
Dyno Show Queen LOL
I think you try your stock lower of almost 8 inches and your3.15(70mm)
I'm at 8.3 lower and 3 inch upper making 1000 on all E it was 930 on 93. We have roughly the same build I don't know your compression and if your cam is efficient as mine. But the ported Heads, 112mm tb, and everything else is identical. If maggi is half as good as it claims you should be right there with me.
Kong Ported 2650, Crawford Racing Port Injection, Weapon X 112mm Adapter, NW112mm TB, Livernois Ported LT4 Heads, Lingenfelter GT32 stealth cam, Haltech Elite, and Carbon by Trufiber Last edited by EDFHOBBIES; 11-29-2021 at 07:48 PM. |
11-29-2021, 06:12 PM | #39 | |
1. Port Injection 2. LPE BB HPFP w/+52% injectors 3. XDI pump w/+60% injectors
11-29-2021, 06:46 PM | #40 |
Wow, so many options. Thank you all for the help. I only thought that I did my homework before I opened this cans of worms. Lol!
I want to stay on 93 pump gas. If needed I can do without the E85. Like anyone else I want as much HP as I can afford. I'm pretty much at my limit. I still want it street friendly. I won't have unlimited access to tuning and dyno. Sounds like I should start with 80 to 90mm upper and 9" lower. |
11-29-2021, 07:16 PM | #41 | |
LOL @ 930 on 93.
11-29-2021, 07:39 PM | #42 | |
