04-20-2019, 08:50 AM | #1 |
Drives: 2019 ZL1 Camaro Join Date: Oct 2016
1LE Rims On A 2019 2SS A10?
Hi,
Looking for some input on this combination. Wondering if this would work? I would like to purchase MMR replica 1LE rims for a 2019 2SS 10 speed automatic with magnetic ride. Tires I'm looking at are Michelin Pilot Sport A/S 3's. Sizes Front 275/35/20 Rear 285/35/20 The diameter of these tires are VERY close to stock 2SS diameters. Widths are slightly wider. I'm wondering if it would be necessary to do the cable relocation on the driver side rear wheel well with these wider tires. I know if I were to run stock size 1LE/ZL1 tires I would need to do the cable relocation to avoid rubbing the inner wheel well. Can I use the tire pressure monitors that came mounted on the stock SS rims? Anyone out there running this wheel/tire size combination? Any issue? Thanks, Tyrolblue67 |
04-20-2019, 09:10 AM | #2 |
Drives: '16 Garnet Red 1SS Join Date: Mar 2014
If you're getting the 1le replicas, it's best to run the 1le tire sizes:
285/30/20 305/30/20. No cable relocation necessary even with 1le sizes. Stock TPMS will work.
'16 Camaro 1SS
'18 Miata GT Gone: '01 Camaro, '14 Camaro, '90 Miata |
04-20-2019, 09:36 AM | #3 | |
SABIO
This
04-20-2019, 11:05 AM | #4 |
My thinking was trying to run an all season tire on the car.
I can't find all season tires in the stock 1LE/ZL1 sizes. I'll need to drive the car in rain and colder temps. Mostly cruising, long road trips and occasional twisties. I'm not going to track the car The car will not be driven in snow. Was wondering why others needed to relocate the cable on the drivers side inner wheel well running 1LE/Zl1 tire sizes? Thanks for the input so far. Tyrolblue67 Last edited by Tyrolblue67; 04-20-2019 at 11:26 AM. |
04-20-2019, 12:26 PM | #5 |
SABIO
Some do a 305/35/30 or a 315 Toyo R888r
04-20-2019, 01:38 PM | #6 |
04-20-2019, 02:25 PM | #7 |
A 305/35 tire would need the relocation. Stock 1le size is 305/30. That 5% makes a difference!
'16 Camaro 1SS
04-20-2019, 05:32 PM | #8 |
SABIO
You asked why some people have to relocate the harness... I wasn't recommending R888r's as an All Season.
04-20-2019, 05:49 PM | #9 |
