03-30-2019, 10:18 PM | #15 |
Drives: 1LEs Join Date: May 2009
Can Apex do 18” ZL1 1LE widths and offsets that clear the brakes? 18x11 +11 and 18x12 +41
04-01-2019, 12:40 PM | #16 |
Drives: 2013 C6Z06 Join Date: Nov 2016
Not sure this really matters compared to all the benefits of running smaller 18s, but has anyone thought about or have data regarding how much more heat will be going into the rims when they are so close to the brakes? Idk how the rims will handle the heat and how much more heat they will keep in the brakes with less space for airflow.
I have a set of 19s now and would like to go to 18s eventually, but I feel this is a legitimate concern as even with 20s the rims get pretty hot. |
04-02-2019, 01:41 PM | #17 |
Probably tired right now
Drives: 1Lap1LE | EV6 FE | 18 F150 Join Date: Sep 2010
Currently they don't do 18x12... but I have told them on FB it's something people want... Maybe in the future.
-Seven
'17 SS 1LE - 1LAP 1LE (Now with more 427!) '18 F150 Platinum Powerstroke diesel '22 Kia EV6 First Edition '18 RS3 (1 of 2) Cumulus Blue '24 911 T (ordered) Formers... '19 RS5 Sportback Sonoma Green | '07 Cayman S 6MT | '16 Audi S3 Prestige Viper Green (APR Stage 3+) | '19 Mustang Shelby GT350R | '17 SS 1LE MBM 575whp all-motor |
04-02-2019, 11:15 PM | #18 |
Drives: 2010 camaro RS,2017 camaro 1Le Join Date: Mar 2016
that doesn't appear to be a stock strut could that impact the fitment?
2017 camaro 1le
ROTO fab, Ported MSD, Ported 95mm tb, 2in TSP catless longtubes, flowmaster x-pipe, flowmaster American thunder npp, flex fuel, |
04-02-2019, 11:21 PM | #19 |
BYND GARAGE
Drives: 17' 1LT Turbo Join Date: Feb 2016
It’s a zl1 1le stock coilovers. Same bolt on design as any stock lt, ss or zl1.
04-03-2019, 05:27 PM | #20 |
Drives: Camaro Z28 Join Date: Jan 2017
Wider 18" wheels are something that can be a possibility in the future for sure.
Regarding the wheel picture above, the strut assembly itself is not main the problem with fitting wide 18" wheels. You have to grind down the knuckle a bit first before you even get to the suspension clearances. More information on that can be found at the bottom of our 6th Gen fitment guide: https://support.apexraceparts.com/hc...-Fitment-Guide - Cory
Cory - Fitment Specialist | Phone: 925.245.0773 | experts@apexraceparts.com
Website | Instagram | Facebook | Blog |
04-03-2019, 05:30 PM | #21 |
Sorry, missed this. Yes the barrel of the FL-5 is the same as the EC-7 and SM-10 so they will fit, but certain sizes and offsets will be tight due to the lip design, meaning the spokes will be close to the caliper. Personally I would go with an ET30 or larger offset wheel and run a small spacer if you had to.
04-04-2019, 07:29 PM | #22 | |
04-05-2019, 12:43 PM | #23 | |
Drives: ISO ss 1le Join Date: May 2018
04-08-2019, 07:00 PM | #24 | ||
I mentioned it in another thread, but we will look into doing a small run of wider 18" wheels for you guys. It would not be a 2019 thing though, just being honest. Quote:
- Cory
04-09-2019, 09:51 AM | #25 | |
04-09-2019, 11:34 AM | #26 |
Drives: 2018 ZL1 1LE 2022 GMC AT4 HD Join Date: Dec 2014
18” BC Forged RZ39 with track spec for my ZL1 1LE
Got an exact second set on order in gun metal gray |
