04-04-2019, 06:48 PM | #15 |
Drives: Red ZL1 Join Date: Jan 2013
Thats the bracket you guys sent me, just need to know where 02 Fbod35 mounted the single bolt end. I like like it in front of the engine vs. Left Side above the exhaust. Thanks
2019 Torch Red ZR1
2015 RED HOT 1LE (traded in) 2018 Garnet Red ZL1-1LE (traded in) 2018 Red Hot ZL1 A10 (traded in) 2015 Z/28 Red Hot w/ GM Wickerbill (traded in) 2009 Siverado 2500HD (Tows and Plows) 2010 Cadillac CTS (Wifes driver) 2004 Corvette Z06 Commemorative Edition (Wife’s car) 2014 Subie Outback (My driver) Cushman Minute Misers and Scooter Cushman Minute Miser used parts abundance ASE Certified Master Mechanic ASE Certified Master Collision Repair Technician |
04-04-2019, 06:54 PM | #16 |
Drives: 18 ZL1 - M6 Join Date: Mar 2019
Hello Elite Team,
Based on the info and his pics, was this installed correctly? I'm getting ready to install the E2 can into the same make/model/year. Thanks... |
04-04-2019, 10:14 PM | #17 |
Drives: 2018 ZL1 Join Date: Feb 2016
Here is a better pic for you guys. I pulled one of the bolts on the thermostat housing and mounted it there. It’s a tight fit but if you angle the bracket right it definitely fits. There’s plenty of clearance between the bracket and belt too. And yes, this is the standard bracket that elite sends with the can.
04-05-2019, 06:36 AM | #18 |
Drives: 2016 Challenger Hellcat, 2018 ZL1LE Join Date: Dec 2009
I can’t wait to install this thing on mine !
Fbody, did you remove the sound dampening material from your supercharger? I’m thinking about leaving mine off after the install.
2018 ZL1 1LE/Red hot 2019 Shellby GT 350R/ Oxford white/ Matte Black Stripes/ Carbon Fiber Dash/ Electronics Package #413 |
04-05-2019, 08:57 AM | #19 |
I did remove mine. I also have the rotofab intake. The two combined real wakes up the supercharger whine.
04-05-2019, 09:14 AM | #20 |
I am absolutely removing the plate while I have the SC cover removed for the E2 catch can install. That along with the Roto Fab should absolutely make a difference.
FBody.. Did Elite ever respond to you regarding the way you have it installed? Do you still have the same issues / concerns? Thanks guys.. |
04-05-2019, 09:28 AM | #21 | |
04-05-2019, 10:16 AM | #22 | ||
I definitely will. The first / best video that I found regarding the installation is linked below. Is this how you hooked yours up?
Another good one.. |
04-05-2019, 10:19 AM | #23 |
Yep. I used both of them videos as guides. The only difference is where I chose to mount my can. Obviously I mounted mine in front of the engine.
04-05-2019, 10:24 AM | #24 |
Thanks Fbod! I wish that Thermostat housing bolt was a little beefier
but it is what it is. Thanks
2019 Torch Red ZR1
04-05-2019, 11:25 AM | #25 |
Drives: 18 ZL1 1LE Join Date: Apr 2013
How hard of an install are these on the LT4? I had one on my LS3 & it was pretty straight forward & a breeze. I was amazed my the amount of blow by oil it picked up. How necessary are these on the LT4 & any issues with them and warranty concerns?
04-05-2019, 01:07 PM | #26 |
Drives: 2010 Camaro Join Date: Nov 2009
Yes, there should be suction if you remove the oil fill cap or our cleanside separator. That shows it is pulling full time evacuation. Good job all!!!
04-05-2019, 01:34 PM | #27 | ||
Coupe Newbie
Drives: 2017 ZL1, 2021 Corvette Convertible Join Date: Jul 2011
Whether a catch can is needed on the LT4 or any engine for that matter will be debated until the end of time. As far as warranty, I think you'll find yourself in a precarious position with a major engine malfunction and GM sees you've got a catch can. Right or wrong, the PVC system will have been modified giving GM a good excuse to deny warranty coverage. I think adding a catch can as part of a high HP build is a no brainer. You're already blowing your warranty so you might as well throw in the can. On an otherwise stock LT4, I'm not sure a catch can is worth the time and effort -- especially if you're hell-bent on maintaining your powertrain warranty,
