Old 08-01-2016, 10:51 AM   #85
HumanWiki
Drives: Car
As a friend of mine noticed, it has been stated that the 6 speed was only going to have 1 OD on the ZL1. Are those the for sure ratios?
http://www.camaro6.com/forums/showthread.php?t=444455
"The six speed manual transmission benefits from active rev match and revised, track-oriented gear ratios that means there’s only one overdrive gear. "
HumanWiki is offline   Reply With Quote
Old 08-01-2016, 12:25 PM   #86
hotlap
hotlap's Avatar
I wasn't aware that the ZL1 has a revised version of the 6-speed. The order guide denotes MN6 uniformly for the SS and ZL1.
I removed the table stating ZL1.
Ronald Reagan -
Old 08-01-2016, 12:27 PM   #87
HumanWiki
Drives: Car
Hopefully we'll see the published ZL1 specific MN6 vs the SS and whether or not the 1LE MN6 will get the same 1 OD variant.
Old 08-01-2016, 02:42 PM   #88
Zeke.Malvo
Zeke.Malvo's Avatar
Drives: 1969 Mustang MaCh1
Originally Posted by EE7 View Post
The 8 and 10 may be identical until 100 mph but the shift speed of the 10 is going to be significantly faster.
What's the shift speed difference between the two?
1969 Pro-Touring MaCh 1 - CHP 427w 10.8 comp - 3140 lbs. - 460 rwhp / 490 rwtq
T56 Magnum || 14" 6 piston front / 13" 4 piston rear Wilwood brakes || Hydraulic clutch || 9" Detroit Locker || TCP Coilovers || Forgeline Wheels 18x10 275/35 front, 19x12 325/30 rear
Zeke.Malvo is offline   Reply With Quote
