01-09-2019, 03:03 PM | #1 |
Drives: 2018 ZL1 Coupe NFG M6 Join Date: May 2017
What do you guys think of this rear drag setup?
I already have MRR Z/28 replicas so these would kinda match the front for trips to the drag track. I'd have an hour and a half drive each way by the way.
1989 Forumla 350 WS6 <- High School
2000 Trans Am Firehawk <- After High School 2017 Colorado Z71 <- Daily 2018 ZL1 M6 <- Not Daily |
01-09-2019, 08:40 PM | #2 |
I would do 17x10 and run a 305-45-17.
2016 NFG 1SS A8
01-10-2019, 06:40 AM | #3 |
Drives: 2017 ZL1 A10 Join Date: Nov 2009
01-10-2019, 07:10 AM | #4 |
You'll have to do the 17x10.5, they don't make a 10" unless you go down to the 15" and then you have to do a brake conversion. I agree, do the 17x10.5 with the 305-45-17 and et street R
01-10-2019, 10:47 AM | #5 |
Is the ET Street in either the bias or the radial good to go for a 3 hour 70 MPH highway roundtrip to the track?
01-10-2019, 12:02 PM | #6 |
I wouldn't buy the bias then, I'd buy the radial
http://mickeythompsontires.com/drag-tires/et-street-r
01-10-2019, 12:06 PM | #7 |
That's just one way? Long trip on any drag radial.
01-10-2019, 02:42 PM | #8 |
Yep...I meant the 10.5
2016 NFG 1SS A8
01-10-2019, 10:45 PM | #9 |
Life's Short, Live Fast!
Drives: 2017 Hyper Blue A10 ZL1 Join Date: Nov 2016
I like it, but would second the notion to go with the R over the SS tires. I'm also looking at 18" wheels because it's so hard to find a 17 I like that will fit over the ZL1 brakes without spending a fortune and I don't want to replace the brakes. If I was replacing the brakes I'd go all out and run a 15" wheel.
Life's Short, Live Fast! https://youtu.be/rTUv2p4T7OA 10.94 at 128 mph, 11.13 at 127mph 870 DA, https://youtu.be/e_X_LcpFp50 11.19 at 127mph 1100 DA, https://youtu.be/OXQiCQdQuH4 11.40 at 125mph 1800 DA
https://youtu.be/uWba1qs8M6Q 11.52 at 123mph 3500 DA TZQPHG '17 ZL1 HBM|A10|Nav|PDR|CFW Hood|ZL1 Mats 12/26/2016 Ordered! 2/8/2017 Built!! 3/2/2017 Brought Home!!! |
01-10-2019, 10:51 PM | #10 |
Yes. My dad runs the Pros, which is even more aggressive than the R, and he drives his an hour and a half each way all the time and has even driven 4 hours one way a time or 2. Well he did. Lately he's been trailering back and forth because he has broken something and had to hitch a ride all the way back home to get his truck and trailer to go back after the car.
01-11-2019, 10:54 AM | #11 | |
@Blackmamba_1LE
Drives: 2017 1LE Join Date: Jun 2017
OG: Pray Perf FBO ET:11.5 @119 THEN:LT4 SC, E85 + Meth :10.6 @135 NOW: H/C Whipple 416ci
01-11-2019, 11:22 AM | #12 | |
01-11-2019, 11:36 AM | #13 |
Drives: 2016 Camaro SS Join Date: Sep 2018
01-11-2019, 11:59 AM | #14 |
At the track on a prepped surface maybe, on the street no. That being said, The fastest cars in all categories are running a 28...not to mention it looks much better then a 26.
2016 NFG 1SS A8
