10-31-2018, 08:26 PM | #1 |
Drives: 2019 Satin Steel 1SS 1LE w/ PDR Join Date: Sep 2017
Stock (LT) 18" Wheels/Tires on a '19 1LE?
I'm looking at a set of stock 18" take offs from a 2017 LT. Can someone please confirm these will fit on my 2019 1SS 1LE? It's on order so I can't test the fit myself. I figure these will be perfect for a winter set up, the stock all seasons on them might get me through a few months too.
IIRC, you could add the 6 piston Brembos to any trim, which tells me they will fit. Thanks! |
11-01-2018, 06:41 AM | #2 |
Drives: E92 BMW M3 Join Date: Oct 2012
J-Rod Built and Matt@FSP Tuned |
11-01-2018, 07:29 AM | #3 | |
11-01-2018, 07:32 AM | #4 |
11-01-2018, 09:26 AM | #5 |
Drives: 2019 ZL-1 Join Date: Feb 2009
The 1LE brakes MIGHT be an issue.....
2012 Yukon XL Denali w/ 6.2 AWD |
11-01-2018, 09:49 AM | #6 |
11-01-2018, 10:34 AM | #7 |
Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
There are guys running 18” track setups on SS 1LEs. So, it’s possible, as long as the LT wheels don’t have an intrusive inner barrel design. The rears will fit. The fronts are the question due to the brakes.
11-01-2018, 03:14 PM | #8 |
Drives: 2018 SS 1LE Join Date: Sep 2018
If you go on Tirerack and select an SS w/ZL1 brakes you can find 18" that will fit, but like others have said, not sure about the OE LT1 rims.
11-02-2018, 06:57 PM | #9 |
Drives: 2000 GMPPSV SS & 2017 ILE SS Join Date: Jul 2017
Sorry, I tried replying but it wouldn't let me type a response.
I don't have pics but I ran the LT wheels all winter last year. Just powder coated them black for this year. THEY FIT! I did use a 3/16" spacers on them because they came with the wheels from the guy I bought them from. He said it was to make them look better, not so tucked in. Front caliper clearance is a non-issue believe it or not. 18" lets you run a less expensive tire and also has a smoother ride due to taller sidewalls. Last edited by Bad Anvil Garage; 11-02-2018 at 07:11 PM. |
11-02-2018, 10:00 PM | #10 | |
