10-18-2021, 07:49 AM | #15 | |
'20 ZL1 1LE A10,
10-18-2021, 08:24 AM | #16 |
Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C) Join Date: Jun 2017
OP, different supercharger but i made 800 on just 93 with my procharger on LT4 fuel system and DSX lowside.
my 2 cents, you should be able to make over 700 or just right at 800 with a 2650, torque would be almost identical as well.
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw |
10-21-2021, 06:19 AM | #17 | |
Dyno Show Queen LOL
Current mod list for me is very similar to yours. Kong ported eforce 112mm TB LPE GT31 cam with 38% (not 32 get the most from the pump) CHE trunions LT4 ported heads (Livernois stage 3) 1 7/8 headers Big Gulp 5 inch intake ATI pulley 8.3 Edelbrock pulley 3.0 With the porting on the blower I'm at 930 on 93 octane of course I'd never take it on the street like but doing so my pulley combo is badazz I'm barely turning this setup. Turning your blower harder and higher compression may make you meth dependent. With all that you have on list I think you be fine if the compression is right. I got detailed info on the LPE Eliminator setup which they sale for the purposes of 850 on 93 and 930 on all E. They told me the main difference on there setup vs others is the thicker head gasket from Cometic vs the stock LT4. I want to say the LT4 is around .053 and the cometic is .079 lowers compression enough and gives them a comfort zone so they can sale a 850 rwhp car on 93 with a warranty. They also install the 3 gal bumper tank for the intercooler system. before I did port injection and blower porting I was at 850 with my lt4 fuel parts and dsx aux. I was running a 9.17 and 3 inch you can see the difference opening it up does for power and efficiency(less heat)
10-21-2021, 07:54 AM | #18 |
Why not? I've been driving and will continue to drive mine daily. What makes it undriveable?
'20 ZL1 1LE A10,
10-21-2021, 10:27 AM | #19 | |
Dyno Show Queen LOL
The fuel system can be stretched out further with power adder that move a lot of air more efficiently. where as a LT4 1.7 blower maybe maxes at just over 700, a 2650 can make it to 850, and turbo kit can make it to 1000. You can't off the oem lt4 blower where the fuel maxes out at. I drive mine all day at 1044 why cant you make that much power?
10-21-2021, 11:59 AM | #20 |
I could spend as much as needed to make whatever HP an LT4 will make, but I've been set from the outset on keeping the OEM blower and running E85 and making whatever that will make. It's been and hopefully will always be a pretty easy car to drive on the road.
'20 ZL1 1LE A10,
10-21-2021, 08:47 PM | #21 |
Drives: A10 ZL1 Join Date: Mar 2018
I’m at 824 Rwhp with a maggie on pump 93
10-22-2021, 10:12 AM | #22 |
Drives: 2015 Camaro ZL1 Join Date: Oct 2020
We have made 870RWHP on pump 93 using a Magnuson 2650. That is what we would consider the limit for a street driven car on 93 octane with this combination.
That being said. Listen to your tuner. |
10-22-2021, 10:27 AM | #23 |
Drives: 2016 Camaro 2SS Join Date: Apr 2018
10-22-2021, 12:20 PM | #24 |
I assume the 870 has little if any correction (0-3%)
'20 ZL1 1LE A10,
10-22-2021, 03:09 PM | #25 |
10-22-2021, 03:11 PM | #26 |
10-22-2021, 07:17 PM | #27 |
I assume on 93 oct.; have you tried 100 oct. tunes?
'20 ZL1 1LE A10,
11-12-2021, 01:04 PM | #28 |
We were able to make 870RWHP on a full OEM LT4 high side (DSX low side) on 93 octane. It is hard up against the limits on the stock injector.
I tried to upload the graph but there must be a minimum post count to post photos. Last edited by Katech_Mike; 11-17-2021 at 10:01 AM. |
