08-06-2021, 01:17 AM | #1 |
Drives: 2020 Chevrolet Camaro Coupe 2SS 1LE Join Date: Feb 2020
Exhaust smell in the car.
Does anyone else get an exhaust smell in the car when you run the ac?
When ever I'm driving and use the ac with the recirculation on I smell like exhaust on my clothes when I get out. And in Las Vegas i'm using the ac a lot. I almost always have the recirc on with the ac. The windows are rolled all the way up so there shouldn't be any fumes coming in. I just wanted to see if any other 1LE owners have noticed this. I'd rather not take my car in and have a tech driving it all over and then say they didn't find anything. The car is still completely stock. |
08-06-2021, 08:09 AM | #2 |
Drives: 2017 Silverado/2017 ZL1 Join Date: Aug 2019
no that shouldn't happen. sounds like an exhaust leak at the manifold or something. Do you smell it when you pop the hood with the car running?
08-06-2021, 10:34 AM | #3 | |
I have a sport bike that has dual pipes that come up under the seat and I’ll get that smell. But the exhaust system is right below and behind so I an see that. Last edited by 2004YZFR1; 08-28-2021 at 06:14 PM. |
08-06-2021, 11:26 AM | #4 |
Drives: 2016 2SS Convertible Join Date: May 2012
Maybe there’s a problem with the AC system that recirculation is drawing air from the exhaust into the car through the rear vents. Try running without recirculation to see if the problem goes away.
I would check the PCV hoses under the hood. The AC system draws fresh air from the engine compartment so maybe there’s a leak that is letting the AC system draw fumes into the car. |
09-14-2021, 07:50 AM | #5 |
Drives: 2021 Camaro SS 1LE Join Date: Aug 2021
I have a similar issue but it's only on startup. Smells like the AC is blowing in an oil smell for like 20 seconds then it goes away..
09-15-2021, 03:52 PM | #6 |
If you are smelling oil then you have an oil leak probably blew back on exhaust and at startup you are smelling it burn off. Faulty oil pan gasket, common problem, I had to have mine done under warranty with only 10,000 miles on it.
09-15-2021, 06:16 PM | #7 | |
It’s not a strong smell, I really only notice the exhaust smell on my clothes when I get out. |
