Old 06-30-2021, 09:31 AM   #29
RamAir02
Shadow Gray '19 ZLE M6
RamAir02's Avatar
Drives: '19 ZL1 1LE M6
Originally Posted by ste6000 View Post
there are websites that you can upload the file to and let them print and ship it for you.
Yes, but it is not at all economical... at least from what I've seen
Shapeways --
YouTube
Old 06-30-2021, 06:54 PM   #30
ste6000
ste6000's Avatar
Drives: 2018 Camaro SS
Shapeways --
well the sites do a more you make. so if you can get a group buy then you can sell them for cheaper.
2018 Camaro SS - Hyper Metallic Blue
ste6000 is offline   Reply With Quote
Old 07-01-2021, 12:51 AM   #31
MakCamaro
Makis
MakCamaro's Avatar
Drives: 2020 Red Hot ZL1 A10
All sites are too expensive. Can someone print one for me? If yes, please let me know so that I give you the dimensions. I will pay the material used and shipping.
Old 07-01-2021, 08:58 AM   #32
pzoom
pzoom's Avatar
Drives: 2021 SS 1LE SHOCK
Shapeways --
It is expensive, but you have to account for time (materials are cheap). My printer (Monoprice Maker that I bought ~4 years ago for $300) takes over 24 hours to print the 6.5" version. That's assuming it doesn't fail in the middle of the print. I have a few of those when I switched from ABS black to PLA green. Running multiples will not reduce time unfortunately. Then there are the small "artifacts" that needed to be sanded, trimmed, etc.
pzoom is offline   Reply With Quote
Old 07-05-2021, 01:09 AM   #33
TurnPikeSpike
TurnPikeSpike's Avatar
Drives: *2014 SS 1LE* 2019 Camaro ZL1/1LE
Could someone modify the original design to fit the 12 Pro Max with a Lifeproof case? The case dimensions are 6.84x3.57x0.44(in) or 173.74x90.68x11.18(mm). I'm not sure how much extra room would be needed for it to fit properly. Also, Xometry.com allows you to upload the file and modify material and some color and it is about $50-$60 depending on material. Thank You
TurnPikeSpike is offline   Reply With Quote
Old 07-17-2021, 05:58 PM   #34
deejayhoff
Drives: Chevy Camaro
print phone holder
If someone wants one printed in black, I can do for $15. You'll have to send me what file you want. I can make some modifications for you, but that may be a little more depending on what you want. Email the file you want printed and I'll do it. deejayhoff@gmail.com
deejayhoff is offline   Reply With Quote
Old 07-17-2021, 08:23 PM   #35
RamAir02
RamAir02's Avatar
That would be amazing! I just emailed you. Thanks!
YouTube
Old 07-30-2021, 01:02 PM   #36
RamAir02
RamAir02's Avatar
Just wanted to follow up here and share that deejayhoff hooked it up! The phone holder works perfectly. Really happy with it and huge thanks to deejayhoff for helping me out
YouTube
Old 08-27-2021, 11:11 AM   #37
TenTwo
TenTwo's Avatar
Drives: Chevy Camaro LT1
edit: never mind I think I figured it out
edit #2: not quite actually. I adjusted the size for a Samsung Galaxy S21 Ultra with a 6.8in screen. The numbers I came up with, in millimeters:
Units: Millimeter
Scale: 4.8176%
Width: 177.1642 mm
Height: 32.5686 mm
Depth: 62.1629 mm
Does that look right? I can't figure out how to save the zip file.
TenTwo is offline   Reply With Quote
Old 10-18-2021, 12:24 PM   #38
NateZ28
Drives: 2019 Camaro 2SS 1LE
I'd pay someone to 3D print this for me. Tired of using the cup holder for my phone.
NateZ28 is offline   Reply With Quote
Old 10-23-2021, 05:30 PM   #39
2SSVERT
2SSVERT's Avatar
Drives: 17 garnet red 2ss vert
Came out pretty good, only took 20 hours to print.Name:  WIN_20211023_17_23_57_Pro.jpg
2SSVERT is offline   Reply With Quote
Old 11-02-2021, 12:59 PM   #40
joekd
Drives: 2018 Camaro SS vert
Having a couple of these printed now, already have a white one done which can be dyed or painted and having a black one run now
Depending on which I like better I may sell off the extra if anyone is interested, this is the Camclip12 size from page 1 of this thread
joekd is offline   Reply With Quote
Old 11-18-2021, 06:49 AM   #41
BrandanK
Drives: 2021 Camaro SS 1LE
Thanks for the inspiration pzoom.
I went a little different route. Vertical orientation between the lower seat bolsters, next to the seat belt. I can put the phone in with the Lightning port up or down; there is a small relief at the bottom of the mount for the Lightning cable. A double sided barb keeps the mount hooked between the center console and carpet.
This configuration might not work for everyone. I am 5'-3" and sit fairly far forward, which creates a small gap between the seat and center console.
Printed on our Markforged Mark Two with Onyx Nylon.
Designed in Solidworks. Made for the iPhone XS
BrandanK is offline   Reply With Quote
Old 05-29-2022, 01:06 PM   #42
david_acm
david_acm's Avatar
Drives: LT1
Do you still have the file for this and do you mind sharing it?
david_acm is offline   Reply With Quote
