Old 02-24-2021, 10:20 AM   #15
Umbriel
Drives: 2016 Camaro SS
Originally Posted by ZO6Ted View Post
Thanks I actually remember seeing that now. Loved it! After speaking with my tuner and my builder yesterday I think I am leaning towards this now. Tuner did say either single or dual band would be fine but get boost control and map sensor from CR. Is yours single or dual band. Thoughts?
Mine is just single, the Dominator upgrade is another $1000 and all I really wanted mine to do was control the port injection and boost control. If you do boost control and dual bands the price of it will be closer to $7000 for it.
Umbriel is offline   Reply With Quote
Old 02-24-2021, 07:24 PM   #16
ZO6Ted
Old badass
Drives: 14GMC 2.9 16GMC Turbos 2020Silv.6.2
My first thought is I don't need the Dominator really but if anyone here can educate me why it would be an advantage I sure would. Rather spend it somewhere else actually.
ZO6Ted is offline   Reply With Quote
Old 02-24-2021, 07:39 PM   #17
Umbriel
Yeah I can't help you there. I didn't feel like I needed it either and my tuner said it wasn't necessary.
Sent from my SM-N986U using Tapatalk
Old 02-25-2021, 06:42 AM   #18
danhr
BAMF SS
danhr's Avatar
Drives: 2016 Camaro 1SS A8
Send a message via AIM to danhr
The main difference between the Dominator and the HP (imo, the "next step down" from the Dominator) are:
dominator allows 2 widebands.
dominator can CONTROL drive by wire throttle bodies
hp has 4 I/O. Dominator has 36 I/O
If those are desireable..... you may want a Dominator. If not.... go with the HP
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock
800 SAE rwhp. 9.4 @ 145 mph.
Old 02-25-2021, 06:58 AM   #19
parish8
Drives: 17 SS a8
If your the type that constantly likes to modify your car the more inputs and outputs the better. An extra $1k isn’t much in the big picture. If you like data those inputs can go fast.
Old 03-01-2021, 01:42 PM   #20
ZO6Ted
Old badass
While I'm making plans for this project I have decided to do LT4 fuel and 525 lowside on my DD 5.3 Whippled work truck, like quickly. Would it be safe to run say 12 lbs on full E85 with sbe? Sam Miller at AMP is my tuner.
Old 03-01-2021, 01:44 PM   #21
danhr
BAMF SS
danhr's Avatar
your low side will run out
you would need like 35 gph of meth to supplement
Stock Longblock
Old 03-02-2021, 11:14 AM   #22
ZO6Ted
Old badass
They were advertising the 525 up to 1k crank hp on 93. I figured no way I'd be over 525-575 wheel with my stock cam 5.3 even on E85. It won't carry that far? Since it's my daily I don't want to supplement with meth so would I have to stay at 10 or so maybe? What do you think?
Correction: It was NOT 1k wheel advertised but 1k crank.
Old 03-02-2021, 12:21 PM   #23
danhr
BAMF SS
danhr's Avatar
They were advertising the 525 up to 1k wheel on 93. I figured no way I'd be over 525-575 with my stock cam 5.3 even on E85. It won't carry that far? Since it's my daily I don't want to supplement with meth so would I have to stay at 10 or so maybe? What do you think?
ok so maybe I was thinking too much along the line of 6.2 stuff. lol.
this truck made 626/638 rwhp on 93 + meth (would I was rate as comparable to e85) on 14 lbs of boost throuhg a 2.9L whipple with long tube headers and circle d 3200 converter.
So if you have more supporting mods than that (say throttle body mainly), you are easily going to hit the 625 rwhp mark I think. a 525 will just about be borderline, I think.
10 lbs, you will be safe.
Stock Longblock
Old 03-02-2021, 01:39 PM   #24
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
I'm running Haltech it has 2 widebands or 1 however you want to set it up.. heck you can get crazy and weld individual bungs on all the exhaust manifolds if ya want! I would ck with the tuner on what stand alone computer to buy.. Haltech, Holley, EFI.. many to choose from.
Fueling options non meth route...
Port method what I did. 800 to 1200hp plus full e85 sitting at 1044 due to stock block.. If your blower doesn't have port injectors you can use plates that mount between the heads and blower.
$4800 2650 Edelbrock
$8.00 NGK 6510 plugs
$1000 Porting
$650 crawfords drilling work and mounting port rails
$800 lD1050x
$300 DSX flex sensor kit
$600 TSP headers
$450 LPE Cam
$130 C5/7R timing chain
$1000 Livernois Heads
$300 ARP LT Head Studs
$150 LS Hyd lifter/trays
$100 Push rods
$185 CHE trunion upgrade
$95 LT4 Head Gaskets
$300 kaytec valley cover
$30 Cam phase lock
$6 water pump gaskets
$10 silicone grey
$350 ATI balancer
$110 blower ring
$2500 Haltech EMS
$500 various lines/fittings for port
$400/550 lowside pump 380LPE AEM or Holley Dominator pump
Or
$2500 for Fore lowside (kinda over kill since your just running port assist but some do not want a hole in there tank)
If your a good shopper you can find those prices like me. the shop labor and tune is the variable.
This will get ya the 1200 plus on a 2650 on all E85.
800 plus on stock blower use the new spacer blocks that came out that fit under the lt4 blower that hold port injectors. I believe they are made out of space age plastic lol so there also a thermal barrier or the aluminum work fine that been out for while works to.
LPE Big Bore pump DI setup and there 1000 hp builds
850 rwhp 93 e85 930 hp (Good lowside with 80 psi plus under load is key with all new -8AN lines an a Less restrictive ck valve are the key ( NOT A DSX OR SMG AUX PUMP a real return style) and proper spacing of there pump is a MUST!!!!!)
Edelbrock 2650
NGK 6510 plugs
Kooks or ARH headers
$500 Big Gulp
$650 LPE 103 TB
$1600 CNCLT4 LPE Heads
$115 Cometic head gaskets to lower compression
$200 CHE trunion upgrade
$535 GT31 LPE Cam L210356914 42% lobe
$490 L230075897 Comps Cams Spring kit (they come on the heads installed)
$1695 LPE Big Bore Pump L710166914
$2500 30% XDI Injectors on sale at other places
$4400 Lingenfelter L730136927 K-DI Injectors 52% over LT4s
$200 L750067414 LPE Ck valve
Intank pumps similar to fore they build there own (classified)
$DSX flex sensor
$450 LPE/ATI balancer
$115 LPE/ATI blower ring
XDI Direct injection katech 800 to 1200 hp (hp depends on your FI type) Basically your running an extra belt driven LT4 HPFP of serpentine belt. It makes perfect sense.. if one pump can do 700 now 2 pumps can do 1400.. just increase the injector size now..
OEM bower, 2650, Twin Turbo, or Centri
NGK plugs
Arh or Kooks
103MM TB / 112MM TB
Rotofab Big Gulp
Cam (at least a 32% maybe even a 38%)
Heads
Trunion upgrade
$4800 XDI pump belt driven
$2500 XDI 30% injectors (1000hp)
$3XXX XDI 45% injectors (1067 hp)
$4000 XDI 65% injectors (1200 hp plus)
$2500 Fore System return style
$300 DSX Flex sensor
Here are the options enjoy!!!
Old 03-02-2021, 09:18 PM   #25
ZO6Ted
Old badass
Thank you I hadn't seen that. Never understood why people like to beat their crap up like that though. A Z71 is 4wd (in most cases) and I think it's more impressive to haul down the road than burn tires. Not cheap.
$1000 Porting
$800 lD1050x
$600 TSP headers
$450 LPE Cam
$100 Push rods
$30 Cam phase lock
$10 silicone grey
$350 ATI balancer
$110 blower ring
$2500 Haltech EMS
Or
Edelbrock 2650
NGK 6510 plugs
$500 Big Gulp
$650 LPE 103 TB
$DSX flex sensor
NGK plugs
Arh or Kooks
103MM TB / 112MM TB
Rotofab Big Gulp
Heads
Trunion upgrade
Thanks for this. I will definitely enjoy examining in detail several times!
Old 03-03-2021, 11:15 AM   #26
JANNETTYRACING
JANNETTYRACING's Avatar
+30 injectors, LPE DI pump, bigger fuel lobe, and a Aux low side should support 1000whp on E60. Not sure about full E85.
If you are ok with moving to a Secondary system I agree with Choda. Crawford PI system looks to be a really good solution. You have to tune 2 ECU's with it however.
+ 30 are done earlier than that why chance it.
+60 are best option.
www.jannettyracing.com
Celebrating 37 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 03-03-2021, 11:55 AM   #27
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
Maybe cuz there 1500 more..hahaha!
Ted why do you not mess with adding port injection to a DI motor. Just wondering why you do not have any builds or videos of you tuning them. L
I know the XDI offers plenty of fuel but what about people like myself that didn't want to spend 14k in parts. I realize it's probably more stockish in appearance and easier to tune and setup. But port makes sense and even using parts like Haltech and Injector Dynamics the price is so much more affordable. The lowside doesnt have to be powerful since it's operating at a lower psi and so on. Just seems really beneficial.
Anyhow just wondering has No one come to you and asked for a port setup or do you tell them to do an XDI setup and not mess with it?
Old 03-03-2021, 12:17 PM   #28
Umbriel
This is a great question and I would be curious to know as well, I went port and saw no cons to it at all.
