07-10-2019, 04:52 PM | #1 |
Baking Vs Cutting Headlights
I ordered some of the diode dynamics rgbw headlight upper and lower DRLs. I remember when I first started looking at the DRLs people were saying they couldnt get them to bake open. Now I see that oracle has instructions to bake and cut. Has anyone baked the headlights on the 6th gen with any success. Should I try baking before cutting? Is there any downside to trying to bake them first? Also any recommendations on a sealant. I know if I cut I am going to have to use some kind of rtv since I wont be able to use butyl tape.
Adrenaline Red
20" 5 Spoke Black Black Side Spear Dual Mode Exhaust MRC Splash Guards 1G1FG1R74G0124089 |
07-11-2019, 06:06 AM | #2 |
The shop that did mine cut them and sealed them back closed. From everything I researched when I was looking at doing this pointed to cutting was the better option as people were getting mixed results with baking.
07-11-2019, 01:02 PM | #3 |
Drives: 2016 Camaro RS Join Date: May 2016
Cutting is easier to me. Seems like a lot more work when baking. I tried to bake on some older headlights years ago and it didnt work out. Ive used the cut method ever since.
2016 Summit White 1LT RS, Brembo Brakes, NPP Exhaust,Front Glowtie, Rear Red Glowtie, Adrenaline Red Interior
07-11-2019, 01:29 PM | #4 |
cutting it is. I'm just going to grab some of the gorilla rtv from lowes and seal them with that.
Adrenaline Red
07-12-2019, 10:21 PM | #5 |
Just lay some painters tape where u dont want the rtv to go. Then pull it off before it dries. Also, make sure you dont touch the inside of the headlight lens. You can blow dust off but dont try to clean it with anything.
07-13-2019, 12:58 PM | #6 |
Drives: 08 Tiburon GS, 2018 Camaro 2.0T Join Date: Sep 2017
On my Tiburon when I added some halo I baked it and it worked perfectly. A little more work but way cleaner results.
2018 Camaro LS | 6 spd | 2.0L turbo | Nightfall Grey | RS package | Technology Package.
--------------------- Order WDGHKX 1100 - 5/08/2018 | 3800 - 6/18/2018 2000 - 5/09/2018 | 4200 - 6/21/2018 3000 - 5/28/2018 | 5000 - 6/27/2018 6000 - 6/29/2018 |
03-10-2021, 08:54 AM | #7 |
Drives: 18hyperbluzl1/22C8 Join Date: May 2017
does the front bumper cover have to be removed to remove the headlights & drl's to install the diode dynamics
03-11-2021, 10:38 AM | #8 |
Yes
07-23-2021, 10:52 AM | #9 |
Drives: 2016 SS 2SS Join Date: Jun 2021
How did this end up going? Any photos from your process?
10-13-2021, 10:45 PM | #10 |
Drives: 2016 1LT V6 RS Join Date: Jul 2021
I wish someone would post a video on where to cut
10-14-2021, 01:46 AM | #11 |
Makis
Drives: 2020 Red Hot ZL1 A10 Join Date: Apr 2019
That, plus do you use a dremel or a soldering iron to cut open the headlights?
Mosaic black 2018 Camaro 2SS A8 (sold) |
Thread Tools | |
