05-07-2023, 11:49 PM | #1 |
Drives: 2010 Synergy Camaro Join Date: Apr 2023
Autocross tire selection advice for a lowly 2010 V6 auto car...
Howdy, everyone.
I have secured a 2010 Synergy auto car recently, and I thought it might be fun to try this beast out with a local autocross group. The initial general idea is the leave the car alone, go out and get used to the thing, and then make improvements if and when they are necessary. The first thing, however, are...tires. I need to replace them, as the previous owner installed a set of mileage/comfort units on the stock 19x8" wheels, and they're freaking terrible. I was thinking of starting off with: A set of 20x8/20x9 SS wheels (I already have a set) And concerning tires...that's where I'm drawing a blank. I was thinking of a set of Conti DWS 06's just to get started, but I don't think they're going to be surprisingly grippy, especially up front with a 245/45 tire. Beyond that, I was leaning more toward something in a 300-340 treadwear, that way, I've got better grip, but also some give if I push it a bit overboard. Or, are the fronts too narrow for this beast? Any suggestions that pop up? I've done autocross before, but it's been a hell of a long time, and the Camaro is what I have to play with (I'm sized like Shrek, I don't fit vertically and shoulder-width-wise in a lot of smaller cars, even all generations of Corvette are out), and I don't have a working data set yet for what to start out with concerning this car. |
05-08-2023, 06:34 PM | #2 |
The 300-340 tires are ok but think you’ll be disappointed if you can find a set of 280 tires that would be probably best. But in auto cross you don’t generally get the tires up to temp since they are short runs unless your on a big course.
Orange Krush II
05-09-2023, 10:43 AM | #3 | |
I think I'd like to put more tire on the front of the car at the very least, or at least square the rolling stock...or am I worrying about nothing at my HP level? |
05-13-2023, 11:40 PM | #4 |
Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
I've been auto crossing my Camaro lately. I have the Goodyear Eagle F1 super car 3 and have been happy with them. But I'm running a 20X10 275/35/20 in the front and a 20X11 305/35/20 in the rear. I do have understeer because of the power level that I'm at but I don't think you'll have to worry about that with your V6, no insult intended. But if you are worried about understeer I would go with a square set up like 20X10 and like a 295/40/20 all around.
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
05-14-2023, 01:59 PM | #5 | |
I'm not insulted/offended by any mention of this V6, I'm actually kind of curious as to what I can do with it concerning the chassis and brakes...and other than maybe a limited slip swap, touching nothing concerning the engine or transmission, other than maybe some bolt-ons in the engine compartment. The car is paid for, and I'll never get enough out of it to buy anything faster, so why not see if I can have some fun with the thing? |
05-14-2023, 02:06 PM | #6 |
Yeah that'll work. One advantage that you'll have with the V6 is that you can run it to it's potential. Because on an engine like mine you have to baby the throttle around trying not to break traction. But I think that you will want a limited slip though.
05-15-2023, 09:00 PM | #7 |
If you wanna try a good tire set try a 285 square set up an if you find a a good used set of 1LE/ZL1 wheels I think you’ll be hooked. I run a set of Gen6 ZL1/1LE wheels 19x11 an 12’s with 315/325’s Supercar 3R’s I haven’t tried it in Auto X but it’s a cool set on the big track. I think with the width front an back it would work as well on a small course.
Orange Krush II
05-19-2023, 07:16 PM | #8 |
Drives: '94 Z28+ '15 Z/28 Join Date: Jun 2009
You do not want 20's on that car. I'd rock some 18's. If you could get yourself a set of 18's then you could have your pick of any of the hot tires out there right now. If you could get an 18x9 or 18x10 and run a 285/30 or 295/30 that would be ideal imo.
1973 Mach 1, 351C cruiser
'15 Z/28 Red Hot, A/C 1980 Z28- resto-mod project 1979 Y84 Trans Am 1986 IROC-Z |
05-20-2023, 12:04 AM | #9 |
IF you don't mind my asking, what is wrong with the 20" rolling stock? The wheelwell openings are a bit huge for 18" or 19" wheels (the stock 19"s are on the car right now), or is it simply an issue with lack of tire availability in a 20?
05-20-2023, 12:51 PM | #10 |
Give speed a chance
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28 Join Date: Nov 2019
Do this! Get some good tires like Michelin Pilot Sport 4S or the A/S version. Regardless of how deep you get into the hobby they will be excellent performers on the street. Run what you have until you decide your interest level. You can always upgrade later.
05-25-2023, 07:03 PM | #11 | ||
There are no top-tier 315 sized 20" autocross tires. There's a few 19's and there's a bunch of 18's. I run 18x11's with 315/30/18's. they might not fill the wheelwell, but they rock the timing sheets!
05-30-2023, 09:44 PM | #12 | ||
Beyond that, yeah, leaning heavily towards shorter wheels. |
05-31-2023, 06:22 AM | #13 |
5th gens are very heavy. Whether it's a V-6 car or a V-8 they are still big. You want as much tire as you can fit under it.
05-31-2023, 11:34 AM | #14 |
I moved on from autocross to doing road course track days after getting my 1LE, but the tire principle is quite similar.
Moving down to at lest 19's opens you up to way more tire choices that are a better fit for performance driving. I still roll on the stock 20x10 - 20x11 because every time I am about to pull the trigger on a dedicated track 19" wheel/tire combo, something pops up that sucks away my "fun money"... The only good tire I have found for the 20" are the Toyo R888R in 285 and 305. I have heard mixed feedback about the R88Rs for our heavy cars as well. I had to work with more "streetable" tire options. My MPSS were a great "all-around" tire. I ran Nitto Invos for a few years which were "OK". Not nearly as good as the MPSS but handled hot laps better then I expected. What Joelster is saying is right. Stepping down to a 19" or 18" wheel that is at least 10-11" wide is the ticket. More tire options available and you need as much cross-section as you can get for these heavy cars. Just getting out and having fun in the car is most of it. Run what you got and see how you do!
2013 1SS/1LE
Corsa Extreme cat-back, Speed Engineering LT Headers with black ceramic coating, C7 Z06 Front Brake Upgrade, Mishimoto Oil Cooler, BMR Tunnel Brace, Mishimoto Oil Catch Can, MSD Plug Wires, Mishimoto Radiator and Hoses. |
