02-03-2021, 12:00 AM | #1 |
Drives: 2018 Camaro ZL1 1LE Join Date: Jan 2021
2018 Camaro ZL1 1LE 20,40,60 rolls
Hey everyone new to the forums, recently bought a ‘18 ZLE. I’ll be doing some rolls in Mexico with friends for fun. I have only roll raced a couple of cars with my current stock set up.
Questions I have.... 1. What mode do you guys recommend for roll racing? 2. What gear and rpm for 20roll? 40roll? & 60roll? 3. Anyone running Mikey Thompson ET Street SS with the stock wheels 19inch? If so how do handle? Hook? Also if possible provide picture(s) Thanks in advance! Excited to be part of the Camaro family |
02-03-2021, 12:01 AM | #2 |
Drives: 2017 ZL1 Join Date: Aug 2020
Sport with all nannies off.
02-03-2021, 08:21 AM | #3 | |
'20 ZL1 1LE A10,
02-03-2021, 09:46 AM | #4 | |
Drives: ZL1 Mosaic Black Join Date: May 2016
Start in 2nd gear for 20 40 and 60 rolls...why? 1. 2nd gear redlines at 79mph 2. in 2nd gear, the supercharger immediately goes into full boost at full throttle 3. be confident in your shift from 2nd to 3rd and run it to 6500 rpm 4. SHIFT HARD from 3rd to 4th gear..this is the zl1s 1 to 1 gear.. 5. HOLD ON tight!! Last edited by Krowser; 02-03-2021 at 09:46 AM. Reason: spelling |
02-03-2021, 11:09 AM | #5 |
Using the A10 in roll racing has been debated more than...Trump... but 1st and 2nd gears are almost unusable in the >= '20 A10 under wot.
'20 ZL1 1LE A10,
02-03-2021, 01:31 PM | #6 |
Drives: 17' ZL1 A10 Join Date: Dec 2020
Agree !!! On an A10 I would say Sport Mode, use the performance shift mode and let it go,,,, on a 35-45mph roll you should be on 3rd gear I think so.
02-03-2021, 03:16 PM | #7 |
The problem I've found is if you go WOT in Sport Drive at 40 mph, it downshifts and spins the tires badly. Thus I start in Manual and shift to Drive maybe halfway thru 3rd around 5000 rpm.
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650. 100+ octanes, no eth, no meth, no N2O. 2/23 - 1031/1004 wheel. 4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes). 2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next. Last edited by JSH; 02-03-2021 at 07:18 PM. |
02-03-2021, 04:11 PM | #8 |
Drives: 2017 ZL1 Join Date: Jan 2017
Track PTM Sport2, Sport1 if you want minimal wheel spin.
Goto Track mode and double tap slowly the TC button and then select one of the two above
02-03-2021, 04:33 PM | #9 |
Drives: ZL1/1LE parts added Join Date: May 2018
Location: Somewhere around Texas pines tress and smooth asphalt
I dont believe most people can handle this at 20 mph ! Most drivers will be safer/faster with traction control on. Smooth sticky asphalt? Smooth concrete ? Yes A road that's bumpy, pot holes and uneven surfaces or hard asphalt that has rough then smooth highway? Your car will make someone a real good donor with the LT4 in a wrecking yard !
02-03-2021, 07:20 PM | #10 | |
'20 ZL1 1LE A10,
02-03-2021, 07:31 PM | #11 |
Manuel!!!
02-03-2021, 07:39 PM | #12 |
02-03-2021, 08:01 PM | #13 |
'20 ZL1 1LE A10,
02-03-2021, 08:47 PM | #14 |
