Old 09-05-2019, 12:59 PM   #1
Android42019
The Black Emerald
Android42019's Avatar
Drives: '17 ZL1, '08 Trailblazer, '11 1LTRS
Shifter rattle/vibration(6spd)
So I started having this issue a short time ago and I sent the car to Chevy this past weekend....to no avail it’s still there, I can only assume they just changed the shift knob/boot and went with it since they acted like it was fixed.
It’s really bad under light load on the throttle, in gears 3/4 it sound thes worst, I said to check tranny but I’m assuming they did not....any info is appreciated...still taking it back Monday I believe.
https://youtu.be/R4fNgGA3WXc
Android42019 is offline   Reply With Quote
Old 09-05-2019, 01:35 PM   #2
tcs13
tcs13's Avatar
Drives: 2017 Camaro ZL1 M6 - Black
Interested in what you find. I have a similar problem, it started about 2 weeks ago. Mine seems to be more noticeable with a good bit of acceleration in 3rd or 4th. I'm going to schedule service with the dealer. If they find anything I will let you know.
tcs13 is offline   Reply With Quote
Old 09-05-2019, 01:57 PM   #3
tx915zl
tx915zl's Avatar
Drives: 2017 Camaro zl1
My 2017 has the vibration, not the rattle.
tx915zl is offline   Reply With Quote
Old 09-30-2019, 05:06 PM   #4
tcs13
tcs13's Avatar
Service Bulletin found
After a long 21 days here is what I hope will be the fix. I had to go back and forth with the service department quite a bit. Hopefully this is your issue and it will save you some time.
#16-NA-078
