Old 10-28-2017, 01:11 PM   #1
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova
Adding homelink
So after a long time we added the Homelink to the 2.0T car on Friday, i am happy to report it all worked out, but it works slightly different, made a plug and play harness out of our Radar harness, but by doing it that way power is of if you turn off the car, it does not loss memory of your presets and works other than that as it was meant to.
P.S. at the same time added the lighted door plate.
2SSRS@Gen5diy is offline   Reply With Quote
Old 10-31-2017, 10:46 AM   #2
k818mn1
Drives: 2016 Camaro SS, Garnet Red
Say what? I didn't quite get that.
k818mn1 is offline   Reply With Quote
Old 11-01-2017, 09:12 AM   #3
yotaman96
yotaman96's Avatar
Drives: 2017 Camaro SS1LE 2000 Trans Am WS6
They’ve made a plug and play harness to add Homelink to cars that did not come equipped with Homelink. The only difference is, the ignition will need to be on to use Homelink unlike the factory setup.
2017 Krypton Green SS 1LE
Magnacharged 2000 Trans Am WS6 manual trans
2002 Trans Am
2015 Ram Crew Cab Cummins
yotaman96 is offline   Reply With Quote
Old 11-02-2017, 09:25 PM   #4
TJay74
Woohoo, rock on. Where do we find the wiring harness and how much?
Some of the newer stuff is going with no Homelink unless the ignition is on, this keeps the thieves from being able to get into your car in the driveway and hit the button to open your garage.
Old 11-23-2017, 07:30 AM   #5
vtirocz
vtirocz's Avatar
Drives: 2017 Camaro 1SS M6
What exactly is needed to get this working on a 1SS besides the harness itself? Trying to gauge the total cost.
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph
Old 11-23-2017, 05:14 PM   #6
2SSRS@Gen5diy
The harness and the new overhead console, that's it.
Old 11-23-2017, 05:54 PM   #7
vtirocz
vtirocz's Avatar
Thanks! Do you sell the overhead console or have a part # for it?
Old 12-15-2017, 11:25 AM   #8
GOMD
GOMD's Avatar
Drives: 2017 Camaro 1SS, 2023 Sierra
23353765
COUPE, W/ O SUNROOF, W/ GARAGE OPENER, GRAY
84026957
COUPE, W/ SUNROOF, W/ O GARAGE OPENER, BLACK
23353762
COUPE, W/ SUNROOF, W/ GARAGE OPENER, GRAY
84026954
COUPE, W/ O SUNROOF, W/ O GARAGE OPENER, BLACK
84026942
COUPE, W/ SUNROOF, W/ GARAGE OPENER, BLACK
84026955
COUPE, W/ O SUNROOF, W/ O GARAGE OPENER, GRAY
23353777
COUPE, W/ SUNROOF, W/ O GARAGE OPENER, GRAY
84026945
COUPE, W/ O SUNROOF, W/ GARAGE OPENER, BLACK
GOMD is offline   Reply With Quote
