04-27-2012, 09:58 PM | #29 | |
Drives: 2008 Bullitt + 2009 Shelby GT-500KR Join Date: Dec 2009
04-28-2012, 07:48 AM | #30 |
Drives: 2012 mustanng gt, 1968 chevy camaro Join Date: Apr 2012
i know....the battery tech is coming up fast.....but i don't think it's gonna make it to that point in my lifetime. if it does, i would think then that scifi is happening too, and i'll be able to go down to the corner store and pick out a new body for myself.
we;ll have to have cleaner/more efficient sources of electricity too. |
04-28-2012, 08:43 AM | #31 |
04-30-2012, 04:28 PM | #32 | |
Drives: 2023 ZLE Join Date: Jun 2009
04-30-2012, 04:43 PM | #33 | |
they're built at the romeo niche plant. they are hand built...and the builder even signs it i understand. i don't know which standard they rate this engine to though. when you say gm rates "net" , is that net at the flywheel, or at the tires? |
04-30-2012, 05:32 PM | #34 | |
GM rates at "Net" power and that is still flywheel power on an engine dyno. To keep it simple let's just say that the power is measured using all of the "ancillary" systems it would have on it when installed in the vehcile. This would include air intake syetm (air filter box and piping), FEAD and the exhaust system, including the resultant restrictions. Many manufacturers rate "Gross" power which usually does not include any of those systems/restruictions. Net power is always less than Gross power for a given engine, and it could be as much as 5% less. This is a general description and I'm not sure what the acutal gross numbers for the LSA in the ZL1 but I know GM rates at Net and certifies this with an outside party. GM ratings show the power available with the driver's butt in the seat. Not sure what Ford does but I would bet it is Gross power. |
04-30-2012, 05:35 PM | #35 |
Drives: 2010 Vette Join Date: Jun 2010
Nobody does "gross" HP anymore. Most (if not all) converted some 40 years ago.
The 2013's 5.8 is SAE certified at 662 net HP. Source: http://www.autoblog.com/2012/04/26/2...30-pound-feet/ |
04-30-2012, 06:10 PM | #36 | |
i don't think ford's rating this engine at gross, as i thinnk that no one uses that anymore. |
04-30-2012, 06:11 PM | #37 | |
Drives: 2000 Mustang GT Join Date: Jul 2009
And a net hp does not give you the power available with the driver's butt in the seat. A chassis dyno rating would be needed for that. |
04-30-2012, 06:31 PM | #38 | |
Drives: Love the one you're with Join Date: Sep 2009
Also as of 2005 if a manufacturer claims to be SAE certified is has to use a third party. |
04-30-2012, 07:28 PM | #39 |
04-30-2012, 07:30 PM | #40 | |
OK, I hadn't seen that referenced anywhere. |
04-30-2012, 07:53 PM | #41 |
04-30-2012, 08:05 PM | #42 |
