01-19-2024, 08:34 AM | #15 | |
Tri-County Camaro SWFL
Lots of good info on this thread. My next project will be a motor for 1200-1500whp.
01-19-2024, 10:21 AM | #16 |
Drives: 2010 Camaro SS , 2011 Colorado LS1 Join Date: Jan 2022
I thought they buy the assemblies from LME? I could be wrong, but I don't they they are an engine builder.
01-19-2024, 10:28 AM | #17 |
Drives: 2014 SS 1LE Join Date: Apr 2014
If money isn't that much of an issue then for sure a dart 6 bolt block.
I went through the same thing last year deciding on which block and ultimately decided on an iron LY6 408. I dont necessarily regret getting a 4 bolt block, but if i could have spared a few extra grand i would have gone 6 bolt. Still ended up making around 1100whp with LSA heads, but the tuner and i stopped at that power level because, guess what, 4 bolt block lol.
01-19-2024, 11:15 AM | #18 |
Anthony S
Drives: 2011 chevrolet camaro 2ss/rs Join Date: Apr 2021
Why not just buy an iron truck block and build something yourself? Not bashing any builders here, but I built my Trans am's motor from the ground up and it was actually quite fun. I learned ALOT about engines and building and she started up the first time I bumped the starter. I'm guessing the reason is because of the power # your chasing?
Follow me on instagram @The_bald_eagle_machine
https://www.camaro5.com/forums/showthread.php?t=600181 Mods: Texas Speed 2 inch headers, high flow cats, and X-pipe. Custom mid-pipe, Borla Xr1 mufflers. Torqstorm Supercharger, 3.1" pulley, ZL1 fuel pump. MGW Shifter, Mcleod RST clutch, Tick master cylinder and Tick Billet bushing reinforced slave cylinder. DSS One-piece 3.5" Driveshaft, Metco Driveshaft safety loop, BCRacing Coilovers. BMR Poly Diff bushings, Poly Rear cradle bushings, Sub-frame connectors, Lower control arms, camber arms, and toe links. |
01-19-2024, 12:01 PM | #19 | |
01-19-2024, 12:06 PM | #20 | |
As for the truck block, it's not going to reach my goal without a lot of risk. I want 6-bolt heads, and if I'm being completely honest, there a bit of vanity involved, with having the LSX or Dart block.
01-19-2024, 08:41 PM | #21 |
Drives: ZL1 Join Date: Oct 2012
Any reason why a RHS block is not being considered?
01-20-2024, 05:48 PM | #22 |
They are expanding that program. Howard Tanner, the owner of Redline Motorsports is closing shop and will be doing nothing but building engines and doing the calibrations at Vengeance.
01-21-2024, 10:04 AM | #23 |
Oh wow! Really? Where is Vengance located? One of my Camaro friends had a build done and tuned by Howard. He might want to know this. Thanks.
01-21-2024, 01:53 PM | #24 |
My research tells me that RHS has been plagued with quality issues.
01-21-2024, 01:54 PM | #25 |
Is Howard already setup and running with Vengeance? If not, how soon will that happen?
01-21-2024, 01:55 PM | #26 |
Onyx_Z7 <— Instagram
Drives: 2013 2ss 1le Join Date: Aug 2014
Dart block here, so far so good. Rn full bolt on, heads, cam. Will be getting a dyno in a few weeks to get a baseline. I’m going with agp twins as well and I would recommend getting the Huron speed coated shorty turbo headers for the agp kit. They come 6 bolt and fit really well on my setup.
427 Dart block, M311 Heads, Pat G Custom Cam, ATI Balancer, BO White Stage 3 TB, Custom CAI, FI Tech Sheet Metal Manifold
01-21-2024, 02:31 PM | #27 |
Nice, I need to get the Huron speed coated shorty turbo headers also for my build.
How do you like the M311 heads?
01-21-2024, 05:08 PM | #28 | ||
I guy I recommend to Redline for his C6 Z06 got this email.
