TireRack
Old 11-17-2023, 08:23 PM   #1
Toronto
Toronto's Avatar
Drives: 2010 Camaro 1SS
Question Questions about spray / nitrous
Hello all, i have returned to ask more questions.
I’ve been looking into running spray on my ls3. Over the summer i got my h/c/i done and now i want more power lol
i’m wondering what supporting mods i should be running or doing prior to getting 75/100/150 shot of spray on my motor. stock bottom end with 110k miles on it
upgrading my clutch next summer and doing some aesthetic modifications but running spray seems to be my main focus.
anyways i appreciate yall & let me know if anyone has any suggestions.
Toronto is offline   Reply With Quote
Old 11-18-2023, 06:31 PM   #2
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
Just make sure you have enough fuel when running nitrous. With a stock fuel pump with H/C/I you may want to upgrade to at least a ZL1 pump.
CamaroDreams76 is offline   Reply With Quote
Old 11-19-2023, 06:01 AM   #3
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
You need a range colder plug for every 75hp and pull 2* of timing for every 50hp. You also need a way to control when it comes in, like with a nitrous controller, but it could be as simple as a manual momentary switch or microswitch on the gas pedal. Controllers have some failsafes ensuring it does not spray below 3000 rpm or when it's not at WOT. I can't imagine the stock fuel pump being good for anything over a 100 shot. Most guys have a dedicated supply because you just can't get a ton of fuel from the Schraeder valve port on the fuel rail.
I actually have a spare NX plate kit as well as a trunk bottle mount from NOS on the shelf if you are interested.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes.
CamaroCracka is offline   Reply With Quote
Old 12-11-2023, 02:07 PM   #4
Badbubba
GrINned & JUICEd
Badbubba's Avatar
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1
Don't skimp, get a nice system. Fuel will be a problem. A dedicated tank worked for me. A progressive system is nice along with tps wot activation. Clutch will be my next item.
GPI SS3 Cam & stuff,N.O. Plate(dedicated fuel tank,progressive,fuel hose upgrade,remote opener,heater,console switches),LNC2000,CTAP,ARH 1 7/8" LTs/gutted cats/X pipe/mufflers,Jet Hot coated LTs,GPI HPT Tune,CAI, Scoop,Rx Catch Can,Gates heater hose relocation, Remote clutch & auto brake res,Metco loop,Momentum Tunnel Brace,TSW Nurb 18",555 & 05,Pfadt trailing arms & toe rods,Autometer WB,Fesler Pillar Pod,LED strips (int),Lloyds floor & trunk mats,LED DRL/front turn & license plate,DRL harness,VLEDs tail lights,Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
Badbubba is offline   Reply With Quote
100 shot, 150 shot, nitrous, spray
