Vararam
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Dragstrip and Launch Techniques Discussion
Old 07-13-2021, 11:05 AM   #1
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
1/4 mile estimate
Hey guys I'm thinking of going to the 1/4 mile drag strip and was wondering what do you think that I could run? I'm making 438rwhp and have the stock rear end and 305/20's BFG'S. All of my mods are in my signature. Thanks
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
Old 07-13-2021, 09:35 PM   #2
Tajefe Couple
Tajefe Couple's Avatar
Drives: Never just fly under the radar
12.22
Old Skool
Tajefe Couple is offline   Reply With Quote
Old 07-14-2021, 04:31 AM   #3
morepowerjoe
I was hoping to be in the 11's but I guess that's not going to happen without drag radials you think?
Old 07-14-2021, 04:42 AM   #4
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
Gonna need a tire and a converter to go 11s
12 camaro ss 427lsx, th400, f310 heads, crower shaft mounts, gpi specd solid roller, shearerfab 2k hp a/w, twin bullseye 88mm turbos, hughes pro ssx bolt together converter, holley dominator, 8.50 cert, backhalf, Ford 9", 33x17x16 tires, c16 fuel
ttshovel is offline   Reply With Quote
Old 07-14-2021, 11:42 AM   #5
joshnmn
2&THEHIT
joshnmn's Avatar
Drives: 5th Gen Camaro; 5th Gen Ram 3500
I’d say 12.8. If you’re asking, probably 13’s til you figure it out. Street tires will definitely make it tough.
joshnmn is offline   Reply With Quote
Old 07-14-2021, 12:41 PM   #6
morepowerjoe
How much time do you think that I could knock off with drag radials? And if I did go with drag radials do I have to worry about breaking an axle? I just replaced them with oem ones.
Old 07-14-2021, 05:49 PM   #7
Ashen 6.2
Ashen 6.2's Avatar
Drives: 2014 Camaro Z/SS
Any rear suspension mods?
2014 Camaro SS L99, Ashen Grey w/Black Leather - Build thread - http://www.camaro5.com/forums/showthread.php?t=491561
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP
Ashen 6.2 is offline   Reply With Quote
Old 07-14-2021, 05:53 PM   #8
morepowerjoe
No not yet. But I am leaning towards changing out the rear sub frame bushings for the poly. What would you recommend?
Old 07-14-2021, 06:16 PM   #9
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2017 Z06, 2019 XTS, 2013 SS
Toe rods, trailing arms are a must if you get drag radials.
My guess is mid to high 12's
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
TheFlyingBananaSS is offline   Reply With Quote
Old 07-15-2021, 02:05 AM   #10
morepowerjoe
Should I do the toe rods and trailing arms instead of the bushings?
Old 07-15-2021, 05:50 AM   #11
102SS
waiting at the tree
102SS's Avatar
Drives: SIM 2010 2SS/RS A6
I agree.
The TQ Converter is worth 4-5 tenths with a good drag radial.
Wheel hop is what breaks axles.
2010 2SS/RS A6 ZL1 Rims
60ft 2.03 13.08 at 107.82 (4/28)
2009 Pontiac G8 3.6L the DD
102SS is offline   Reply With Quote
Old 07-15-2021, 06:17 AM   #12
TheFlyingBananaSS
I did all 3 and have no wheel hop. I also did delrin control arm bushings.
Old 07-15-2021, 06:32 AM   #13
morepowerjoe
So would you point me in the right direction of best brands and parts needed for toe rods, trailing arms, control arm bushings, and subframe bushings? Thanks guys.
Old 07-15-2021, 06:35 AM   #14
TheFlyingBananaSS
I have BMR trailing arms and Toe rods. I put in Detroit speed cradle bushings. And I believe the delrin control arm bushings were GM. But lots of good brands out there to pick from. Do some research.
