01-22-2019, 09:15 PM | #15 | |
One quick question, though, don't you need to polish after the 3000 grit? That wax will not remain there for long.
01-22-2019, 09:18 PM | #16 | |
Drives: camaro ss Join Date: Nov 2018
01-22-2019, 09:23 PM | #17 |
By the way OP, beautiful car; colors are superb.
01-22-2019, 09:27 PM | #18 |
Drives: '23 1SS Sharkskin A10 Join Date: Sep 2018
Thank you sir. Excellent tutorial. I appreciate the help!
Previously Owned:
2018 Silver Ice Metallic Camaro R/S 1992 Dark Teal Camaro R/S 305 V8 |
01-22-2019, 09:30 PM | #19 | |
Drives: 2017 SS A8 Hyper Blue/White Stripes Join Date: Jun 2010
Good Luck
2017 Camaro 2SS Hyper Blue
2011 Camaro 2SS 2004 Corvette CE SOLD |
01-22-2019, 09:41 PM | #20 |
Thanks MemphisSS and thanks to everyone!
Previously Owned:
01-22-2019, 09:42 PM | #21 |
Normally I would wait to put polish or wax on, for a large freshly painted area. But for small chips I go ahead and apply after the paint is dried and wet sanded, due to the small size.
01-22-2019, 09:44 PM | #22 |
Previously Owned:
01-23-2019, 07:34 PM | #23 |
Drives: 2LT RS Yellow Convertible Join Date: Aug 2016
I had a chip on the A pillar, maybe 3 mm. I used Dr ColorChip and applied several layers. The result looks pretty good. If you have no clue that there was a chip, you won't see anything. I guess if I would have sanded it a little bit, it would be much much better. Otherwise I was pretty happy with the result. Better than repainting and paying $500.
Gold Rush
01-23-2019, 08:03 PM | #24 | |
Previously Owned:
01-23-2019, 09:33 PM | #25 |
Drives: 2021 BMW M2 Competition Join Date: Oct 2008
I got a chip from a rock kicked up by a truck a few months back. It was the first blemish on mine and it made me absolutely sick. The chip was on the nose above the headlight. It was like yours where the plastic bumper material distorted and caused a ridge. So first step was to flatten that out. I used the abrasive tip of the GM OEM Touch-Up Paint and it worked nicely. What I like is that the tip is small, so if you're careful, you can flatten the rough edge without touching any area outside the chip.
Once I had it smoothed out, I used a 000 artist brush with the touch-up to fill the chip, waited half a day or so, and then used the Langka Blob Eliminator to level off the touchup. It's the same idea as Dr. Colorchip, and both are good DIY solutions for chips IME. I'm super-fussy, like you , so I actually did the process daily for almost a week until I was satisfied with the results - the Langka solution is essentially paint thinner, so if you don't like it, you can remove all the paint and start over. Once I was satisfied with the repair, I used the clear coat that comes in the Touch-Up bottle, sealed it, and that was it. The repair is decent, and only visible if you get close to the area and are looking for it. To me, it makes a lot more sense to do the spot repair rather than repaint the whole bumper. Good luck.
2021 BMW M2 Competition 6MT
2011 Candy Lime Green Kawasaki Z1000 (1/4 mile - 10.38 @ 129.61 mph - stock) ---------- Previous: 2018 Summit White 2SS 1LE; 2015 MINI Cooper F56 6MT; 2015 BMW M235i 6MT; 2003 MINI 5MT; 2005 Mustang GT 5MT |
01-23-2019, 10:58 PM | #26 | |
I'm guessing the abrasive tip on the OEM touch-up bottle I mentioned above might be 2000 grit, but not sure. Do you know?
01-24-2019, 05:55 AM | #27 | ||
Such a nice car wjones14, I know how you feel!
Previously Owned:
01-24-2019, 07:00 PM | #28 |
Drives: 2015 Topless Btch RS Join Date: Mar 2016
