12-29-2017, 11:48 AM | #1 |
Drives: 2017 Red Hot SS 1LE Join Date: Jul 2017
Ss 6m fluid?
Hey all, first post! About 6 months into ownership of my 17 ss 1le and am looking to change the transmission fluid. I've seen some posts of people putting atf in the manual trans and others suggesting synchro mesh or redline mtf. Thoughts on what I should get? I live in the south so it's not much below 30 degrees f. Thanks!
12-29-2017, 12:14 PM | #2 |
Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C) Join Date: Jun 2017
subbed to see what everyones thoughts are. i also would like to know what is recommended
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw |
12-29-2017, 08:53 PM | #3 |
BigShow
Drives: 2017 1 Camaro + Chevy Avalanche Join Date: Oct 2014
Why are you changing fluid?
12-30-2017, 09:41 AM | #4 |
The stock fluid seems to perform poorly especially during cold Wx.
12-30-2017, 10:36 AM | #5 |
Drives: 2017 2ss, m6 Join Date: Jan 2017
I have RP MaxATF in mine so it satisfies the warranty requirement. No doubt there are better fluids out there but they will not meet the Dex3 requirement. Once I eclipse the warranty period I will go with a synchromesh fluid. With that said the MaxATF has done very well for 30+ track hours and is better in the cold weather.
12-30-2017, 05:21 PM | #6 |
Why are people using atf in the mtf? Can someone explain?
12-30-2017, 07:22 PM | #7 |
Drives: 2016 Camaro 2SS Join Date: Dec 2015
They were designed to accept ATF... to make things easier I guess.
I put RP Synchromax into mine at about 5k miles and noticed a big difference in shift feel and transmission heat. The shifter is more consistent, especially at lower temps, and engagement is slicker. The transmission also runs about 10 degrees cooler during long drives (3+ hours) with some back roads and highway pulls. I used to use ATF in my previous manual cars, T56 and TR6060, and I think Synchromax is worth the extra $. It removes that last bit of vagueness these modern TR6060 boxes have. I do have to say that I didn't know it had an effect on warranty... I'll call a Chevy dealer and ask, just to get a bit more info.
01-13-2018, 10:16 AM | #8 |
Drives: 68 big block Join Date: Oct 2008
Just switched to Redline D4. A noticable improvement in cold shifting. Very smooth when warm. I like it.
02-04-2018, 07:33 PM | #9 |
LT4 M6
Drives: 2018 ZL1 1LE Join Date: Nov 2010
What about the Mobil 1 ATF fluid. It worked really good in my 2011 m6 car. It noticably shifted way better. Was going to use it in my 2018 m6 unless if I really should not.
02-13-2018, 12:26 AM | #10 |
Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
On my 2016 1SS, the trans was low on fluid. The trans shifted OK, not great and always kept pretty cool (for manual trans fluid) even on track. I went to go add and/or remove fluid to add some Redline, but found the trans to be about a quarter (25%) of a quart low.
02-17-2018, 06:50 AM | #11 |
Drives: 2019 zl1 6 speed Join Date: Jul 2017
I used royal purple as well. Call it whatever but imo, it is always good to change your oil, tranny fluid, and diff after the break in period. All the sharp edges and burs, or unecesary rubbing should be worn down by then, and I don't want that stuff in my fluid. My dealer asked me why I was doing it too, lol!
02-18-2018, 01:21 PM | #12 |
Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
Reference this thread (scroll to later pages for torque specs): http://www.camaro6.com/forums/showthread.php?t=492814
I used the fluid GM recommends in the owners manual as well as their service procedure (except rather than using the temp sensor as a drain, I removed the crossmember and used the real drain plug on the passenger side/rear, since I was replacing the fill and drain plugs with a magnetic plug from Dimple).
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph |
Tags |
mtf atf ss 1le fluid |
