Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum
Old 01-07-2017, 02:19 PM   #1
adamx
Drives: 2010 camaro
Front subwoofers with no sound this cold morning
Anyone else have this happen? Wasn't sure if a fuse blew or what, but this morning, it was cold (it's been colder), and absolutely no sound came out of the front subwoofers until the car had been on for 30 minutes.
Is there even a fuse specifically for them? The other speakers worked okay from what I could tell.
adamx is offline   Reply With Quote
Old 01-07-2017, 05:14 PM   #2
Snoman
H-Town Camaro Club
Snoman's Avatar
Drives: 2013 Dusk Edition 2SS/M6/Sun/NPP
The doors have a 6.5" woofer cone inside each and there is no fuse for them as they are wired directly to the amplifier. A speaker not producing sound can only be three possibilities if system power is on;
  • Voice coil has been broken apart, disconnecting the electrical path
  • Speaker wire path has been cut or disconnected
  • Amplifier is not producing current
The term "subwoofer" is indicative of an independent driver mounted in a dedicated enclosure capable of reproducing a 20hz (or lower) note. Generally requiring an 8" round driver at a minimum.
Snoman is offline   Reply With Quote
Old 01-07-2017, 05:45 PM   #3
Dizzy82
Dizzy82's Avatar
Drives: 2011 1LT/RS A6 RJT SuperCharged
There is no front sub.
Power is worthless without control. The 2nd protects the 1st.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ
Dizzy82 is offline   Reply With Quote
Old 01-08-2017, 07:27 AM   #4
adamx
Drives: 2010 camaro
You say there's no fuse for them, but wouldn't there be for the amplifier?
I always thought they were subs with how much bass they put out. Like not great subs, but subs lol.
Old 01-08-2017, 08:02 AM   #5
sycraft
COTW 5/06/2013
sycraft's Avatar
Drives: 2017 Corvette Grand Sport-Ho-Vette
some call this the front sub...its just a speaker
2017 Grand Sport, Borla X Pipe.....Enough Said
sycraft is offline   Reply With Quote
Old 01-08-2017, 08:04 AM   #6
sycraft
COTW 5/06/2013
sycraft's Avatar
these are the others..
