Old 01-28-2021, 10:55 PM   #1
20Bluezl1
ARH header installation
So I have been trying to install the passenger side ARH 2" header and I can't get it in. I'm frustrated because my Swaintech finish is getting all scratched.
I have removed the following:
Coolant tank
Coolant lines
Aluminum skidplate
Stater
What is the trick to get them in. I have read that you might have to remove the motor mount but I really dont want to go that route as guys have install them without removing.
Any advice is appreciated
Old 01-29-2021, 07:49 AM   #2
Camaro#7
Drives: 2021 Wild Cherry ZL1 1LE, A10
I could not get my 2" ARH headers in without removing the motor mount. It looks like it's a pain but after doing the same process as you have and finally removing the motor mount I was wondering why I didn't do that it in the first place. It is actually pretty easy to do.
Camaro#7 is offline   Reply With Quote
Old 01-29-2021, 08:52 AM   #3
RG20SS
RG20SS's Avatar
Drives: 2021 ZL1
If you havent thrown the dip stick out the garage, you havent struggled enough lmao
I fought that stupid thing with my 2009 G8 installing the headers. Next morning I walked out and stupid thing dropped right in. Sometimes you need to take a break. lol
2021 Wild Cherry ZL1 A10 Fully optioned ROTOFAB CAI, KOOKS 2" HEADERS W/GREEN CATS, 2.3 UPPER PULLEY, FORCED INDUCTIONS INTERCHILLER, EXODUS TUNED 654HP/718TQ
2020 Rally Green 1SS *SOLD
RG20SS is offline   Reply With Quote
Old 01-29-2021, 08:54 AM   #4
sickss228
Drives: 18 ZL1 mostly stock
Removing the passenger motor mount is the only way to slip them in without scratching the hell out of them. It's really not bad, just takes a little time. I found a wobble extension and a swivel socket makes quick work out of it. I didnt even have to remove the starter when I installed mine.
07 LMB Z06 Cartek 4x heads and cam, ARH, Vararam, FAST 102, NW 102
18 ZL1 M6 MTI cam, FED heads, FBO's
sickss228 is offline   Reply With Quote
Old 01-29-2021, 10:27 AM   #5
20Bluezl1
How should I go about removing the motor mount?
Old 01-29-2021, 11:25 AM   #6
closs2sx
closs2sx's Avatar
Drives: 1970 chevelle
my 2" arh went in from the bottom with ease on the passenger side. The car was on a lift did not remove starter or coolant tank or lines, did not remove motor mount and did not scratch coating.
On Order 2018 ZL1 1LE Garnet Red Tint Coat Metallic
MY Car
2015 Z06 Z07
Daytona Sunrise Orange Metallic
Dads Car
2013 ZL1 vin 963
Crystal Red Tint Coat/Black Wheels
Exposed Carbon Fiber Insert
6 Spd Manual
closs2sx is offline   Reply With Quote
Old 01-29-2021, 11:52 AM   #7
20Bluezl1
This is some weird shit how there is inconsistencies with installation. I tried from the top and the bottom and I'm scratching the coating. The driver side I took the steering shaft and nice and smooth.
Old 01-29-2021, 02:35 PM   #8
sickss228
If your scratching the coating take the entire motor mount out, I think there were 3 bolts holding the bracket onto the engine block and the pad on the frame was another 3 bolts. I have my car down to the shortblock right now and still cant get my passenger side header out, some people just get lucky, who knows!
Old 01-29-2021, 03:00 PM   #9
Alain
Alain's Avatar
How are you guys supporting the motor on the passenger side after removing the mount and while trying to install the header???
2018 ZL1 1LE/Red hot
Old 01-29-2021, 03:14 PM   #10
20Bluezl1
Great question, I was just thinking that myself. Also I was wondering if I'm removing the motor mount is it a good idea if I install BMR motor mounts that are smaller and lighter?
http://m.bmrsuspension.com/?page=pro...productid=1778
Old 01-29-2021, 03:37 PM   #11
20Bluezl1
I was reading the instructions to the BMR mounts and they don't say that the motor needs to be supported. That has my mind going in circles. I'm assuming that the other mount will hold everything in place until you swap them out. Also they left out any torque specs I gave them a call and said 43ft lb for bolts to motor and the other end with the poly bushing just leave 2 threads exposed.
Old 01-29-2021, 05:43 PM   #12
sickss228
Use a jack and a block of wood like a 4x4 under the oil pan. You might have to lift the motor up slightly to get the header to slide in easily.
Old 01-29-2021, 05:55 PM   #13
20Bluezl1
I'm thinking now if I should replace the mounts with BMR.
Old 01-30-2021, 11:26 AM   #14
Alain
Alain's Avatar
You should have specifically asked them about supporting the motor while replacing the mounts when you called.
My mind is going in circles also about this. Dealing with that motor mount during install is one of the reasons I’ve held off doing headers.
Is this how you did it?
Im assuming the Oil pan won’t get crunched while doing this.
