Old 03-27-2019, 02:36 PM   #29
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova
Originally Posted by ~Jb View Post
Would you sell the rear view camera kit without the rear spoiler? Basically everything and then just send the rear camera loose for modification?
why dont you call, lets see whats on your mind?
2SSRS@Gen5diy is offline   Reply With Quote
Old 03-27-2019, 06:55 PM   #30
DangerZL1
Drives: 2023 Black ZL1 Auto
Is a ‘19 front camera in the works with the new wiring?
Old 03-27-2019, 07:46 PM   #31
soyboy
soyboy's Avatar
Drives: 2016 BMW M3 ZCP
Any plans to sell just the modified blade spoiler? Would like to swap the stock ‘19 ZL1 spoiler for a blade spoiler but retain the rear camera functionality.
soyboy is offline   Reply With Quote
Old 03-28-2019, 10:03 AM   #32
2SSRS@Gen5diy
That is is taking a lot longer then we planed, more info soon.
That can be done but you will need to call us to see how we do it.
Old 04-04-2020, 02:52 PM   #33
~Jb
~Jb's Avatar
Drives: 2018 ZLE
Now that the 2020's have the camera in the shark fin antenna, any chance we will see the option available for purchase on you're website?
2018 ZL1 1LE (CARBON/PDR/NAV)
~Jb is offline   Reply With Quote
Old 04-06-2020, 04:58 PM   #34
Firecaptain
Firecaptain's Avatar
Drives: '22 Summit White ZL1 A10
Any pics of the backside of the Bow Tie?
I'm thinking of a mod like that as I am going with a ZLE wing, and removed the camera out of my stock spoiler, so that part is covered.
Wondering how big a hole I'll need in the deck lid.....
Thanks
Originally Posted by 2SSRS@Gen5diy View Post
I know GM is working on one for the 2020 ZLE, but so are we, for the 2018-19 cars, and we came up with this, There is room in the trunk to mount it, all you have to do is move up the Bow tie, closer to the 3rd brake light, and drill a hole in to the trunk lid, this is what the Bow tie looks like with the camera in it.
what do you guys think?
Firecaptain is offline   Reply With Quote
Old 04-06-2020, 06:16 PM   #35
2020 ZLE did not even get the wiring back to the shark fin, but still a good question for Offer.
Old 04-06-2020, 06:32 PM   #36
~Jb
~Jb's Avatar
Drives: 2018 ZLE
That is correct mlee. While the 2020 ZLE did not get it, the regular ZL1 and the SS did, so the parts should now be available?
Old 04-06-2020, 06:35 PM   #37
My comment was directed at the wiring, plugs etc which would not be available. The GM engineers explained this part to me at Camaro Fest last year. It's essentially a 2019 in that regard but I'm sure Offer can handle the wiring with no issue. Just not an easy plug and play.
Old 04-06-2020, 06:41 PM   #38
RUQWIKR
RUQWIKR's Avatar
Drives: 1LEs
Per the GM Online Order Guide, the 2021 ZL1 1LE still doesn't get the camera mirror. A 2SS or regular ZL1 without a sunroof use the same headliner harness. This should be some key strokes in an Engineering Work Order for them.
RUQWIKR is offline   Reply With Quote
Old 04-06-2020, 07:24 PM   #39
Just passing on what they told me. There's some wiring that could have been left in to make it easier is all I know.
Also the reason for not putting it in the ZLE was the wing was in the bottom of the picture. When I mentioned it just gives good depth perception sort of like adjusting your side mirrors where you see the side of the car I got some nodding heads. Also, mentioned that currently the wing is dead center in the mirror which is even worse.
Also one of the main reasons for moving it to the shark fin on the other models is it's closer to the driver so a much better distance perception.
Old 04-07-2020, 06:03 AM   #40
01pewterz28
#TeamBeckyD
01pewterz28's Avatar
Sweet I would love to have that on my 17 vert going via the bowtie is a great idea.
#TeamBeckyD
**FIFTY HBM 2SS VERT**
Old 04-07-2020, 09:42 AM   #41
~Jb
~Jb's Avatar
Drives: 2018 ZLE
Ahh... Makes perfect sense. I did assume the actual harness Gen5diy was custom anyway, but maybe not. I thought that maybe up higher would make the wing less of any issue, but again who really knows.
It would probably the best to find a 2020 Z and fit the 1LE wing on to see how it is in the mirror.
Also, is anyone aware of any pictures of just the camera unit itself? Maybe 3D printing a new center support for the 1LE wing would be a better solution?
Old 04-07-2020, 09:41 PM   #42
A-A-RON
A-A-RON's Avatar
Drives: Chevrolet Camaro ZL1
Originally Posted by rlarsen462 View Post
So we are not able to leave the bowtie in the factory location, it must be moved higher on the trunk lid to make this work? I think that will be a deal breaker for most considering it will probably require bodywork to fill in the hole left by the original bowtie, no?
This is all you need then.. The camera uses a BLUE FAKRA GPS cable. Believe me, I know.
A-A-RON is offline   Reply With Quote
