11-08-2021, 10:53 AM | #29 |
I think what he was eluding to was a removable bra… which is kinda what I thought you were speaking to as well. If you said clear bra or PPF, it would have been a bit more clear. I agree, PPF (self healing) is the best solution, albeit expensive.
11-08-2021, 12:21 PM | #30 |
Hmm, having never used removable it didn't occur to me. But yes, clear bra.
'20 ZL1 1LE A10,
11-08-2021, 01:03 PM | #31 | |
I have Xpel on the front and mirrors, which definitely helps a lot. However, I still had one or two small rocks penetrate that and go mess up the paint underneath, so I don't think anything can realistically provide 100% protection. Trying not to follow semis or bro dozers with no mudflaps also helps.
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 Last edited by arpad_m; 11-08-2021 at 07:15 PM. |
11-08-2021, 01:28 PM | #32 |
Drives: Chevy Silverado Join Date: May 2020
Has anybody used the RPI Design splash guards on a 2020 and up MY? Their website indicates up thru 2019 MY.
11-08-2021, 02:33 PM | #33 |
Drives: 22 Camaro 2SS, 20 Subaru Crosstrek Join Date: Aug 2021
I can’t say for sure, but there is no reason they won’t work. From what I have seen, RPI seems to forget there are model years after 2019 on pretty much all of their product listings. I asked one of their people about it here once and got no response from them why whatever item it was wouldn’t work for 2020 onward. It may be petty of me, but that lack of care or response is enough to make me steer away from buying from them in general. YMMV.
Earth is an oblate spheroid
2022 | 2SS | M6 | NPP | Summit White | Carbon Flash Wheels | Black Lugs | Red Calipers | Adrenaline Red | Red Knee Pads | Nav | - 1100 - 8/16/21 - 3000 - 9/21/21 - TPW 10/18/21 - 3400 - 10/1/21 - 3800 - 10/20/21 - built 10/19/21 - 5000 - 11/12/21 - 6000 - 11/13/21 |
11-08-2021, 02:51 PM | #34 | |
11-08-2021, 09:44 PM | #35 |
Thanks for the replies. Will probably go with the ZL1 Addons.
11-08-2021, 10:10 PM | #36 | |
Drives: 2021 2SS 1LE Join Date: Aug 2020
No matter which brand you choose to buy, take a careful look at the available pictures of the installed splash guards so you can compare how much they hang down (lower is better to block rocks) and how far to stick out laterally from the fender well (further is better if you want to block rocks). Some brands may look great, but they don't hang down very far or don't protrude laterally as far - kind of negates the point of installing them in the first place. |
11-09-2021, 04:47 AM | #37 | |
11-09-2021, 05:28 AM | #38 |
Drives: 2018 Camaro SS Join Date: Jan 2021
Splash guards
Has anyone tried rock blokz? I think they fit the lines of the camaro better
https://rokblokz.com/products/chevro...sh-guards-2016 |
11-09-2021, 11:37 AM | #39 | |
Drives: 2SS 1LE Join Date: Oct 2011
2018 2SS 1LE 2023 Colorado ZR2 2022 Stinger GT-line AWD |
11-09-2021, 11:54 AM | #40 | |
Whatever I buy will end up getting double sided tape at the metal edge. As well, and if possible, I’d reach behind the liner and insert some type of backer nut(s) so they can be torqued down properly. One and done for me..just want it to look and work as it should. For anything more than $50, you’d kinda hope that you could use existing screws / backing retainers w/ double sided tape already applied, like ZL1 Addons. Last edited by Chutzpah; 11-09-2021 at 09:13 PM. |
11-09-2021, 05:06 PM | #41 | |
11-09-2021, 08:23 PM | #42 | |
...but then, as you say, they don't extend down as far as ours, which may or may not matter with side skirts... decisions, decisions
