12-18-2018, 06:15 AM | #15 |
Drives: 18 zl1 Join Date: Aug 2017
I almost always engine brake with the paddles. from speed, I'll usually drop 2 gears at a time, in odd numbers. for example, getting off the freeway, I'll usually tap it into 7th to anticipate getting onto the off ramp, once on off ramp, double tap to 5th. I'll let the engine slow me down to under 2k, then I'll double tap to 3rd. By then I'm usually on the brakes as well, once under 2k I'll tap down to 2nd. I rarely ever tap down to 1st unless I'm in a parking lot and only going ~10 mph or less.
I've literally done this 99% of the time ever since I bought the car. the only times I let the transmission do it's own thing is if the car isn't warmed up all the way yet. no problems here other than the crazy jerking going into 2nd or 1st from a higher rev than normal, but I never drop my car into 2nd or 1st in a manual either to slow down either, so tit for tat. also, if you goose the throttle in sport or track mode and the car goes into performance shift mode, while in that mode, it will automatically downshift for you. Last edited by crosive; 12-18-2018 at 07:46 AM. |
12-18-2018, 09:32 AM | #16 |
I like to use the Paddles or Shifter for wot blasts from a roll. I like the fact that when you are in manual mode, if you hold the left paddle or hold the shifter back, the Transmission will REV match down shift into the optimal gear. Then after you go wot just slap the shifter back to the right and let the computer shift.
2016 NFG 1SS A8
02-04-2019, 08:24 PM | #17 |
Drives: 16 2SS Convertable Join Date: Feb 2018
Have you ever tracked your car? Paddle shift up and down, keeping rpms at best power range to accelerate or decelerate with minimal braking. Chewed up more than one vette, mustang, challengers can’t play because they corner like bricks. Find a race track and go play with your car.
2SS Convertible A8, NPP, GMPP CAI, Flow tie grill, Mishimoto Oil catch can, Eibach lowering springs.
02-05-2019, 11:54 AM | #18 | |
Howdy! Pete here...
Drives: 2017 50th Anniv 2SS, A8, NPP, MRC Join Date: Jul 2009
I do use a combination of brakes and downshifting in my A8 to get great rev match sounds on decel, but am careful not to downshift from any gear until the RPMs are between 2000-1500. And I never downshift below 2nd gear. Technically, the car will deny upshifts and downshifts that are outside of safe parameters (to protect the engine & transmission), but I'm not taking any chances. This approach mirrors how I used to shift in my first two Camaros, which were 5-speed and 6-speed respectively. In my opinion, if you drive an A8 and aren't using manual mode when you can, you're missing out on half the fun!
PnCRedJwl2SS
2017 50th Anniversary Edition, A8, NPP, MRC, w/Sunroof and Glow-tie! ___________________________________________ ___________________________________________ Ordered from GM Delivered to dealership and home 9-16-16 This car is a beast! |
02-05-2019, 10:41 PM | #19 |
Drives: 17' 2SS Camaro A8 Vert NPP Join Date: May 2017
I'm not a big fan of the Active Fuel Management system on the Camaro. I don't like the 1 second delay when getting on the throttle (I presume the 1st time as it then blips the car into a more responsive mode). I also don't like how it does nothing for you in the braking department. It will run 7th gear almost to a stop to save fuel. The car seems to just blast into stops like this.
I run the Automatic in traffic. Otherwise it's 100% in manual mode! Way more fun. When I am approaching a stop, I downshift to keep the RPMs around 2.5-3.5K through 2nd gear, then I let the car shift into 1st once the car stops. Even more fun, sometimes the light will turn green and you're already in the right gear if you want to have some fun. This eats fuel. But, it saves your brakes, and I'm not sure how the trans will like me 3, 4, 5 years from now. I really wish the Auto mode was more responsive, but I just don't like it being dead until you hit it that first time. I always want instant feedback from the throttle when I need it, like a manual. |
02-06-2019, 12:34 AM | #20 | |
Drives: 2016 Camaro SS Join Date: Jan 2019
02-07-2019, 07:39 PM | #21 |
I like to shift manually just to hear the exhaust (npp sport or track mode)
How many people here have just flat out matted the pedal and let it shift on its own doing a 0-60, or 1/4 mile? Damm can that thing shift fast!! Dont do it often but love the whole rush doing it for sure!!! |
02-08-2019, 04:26 AM | #22 | |
Drives: 2017 2SS A8, 2018 Macan GTS Join Date: Sep 2017
02-08-2019, 09:07 AM | #23 |
You obviously don’t know how to use them so don’t use them
02-09-2019, 06:28 AM | #24 |
Drives: '17- 1ag37 V6 traded, for 1SS 2018! Join Date: Mar 2018
I note that in touring, if I have selected the manual mode, and coming to a near stop, the thing will shift to first, and won't upshift unless I kick it up deliberately.
Suppose it makes sense. |
02-09-2019, 07:39 AM | #25 | |
Howdy! Pete here...
Yeah baby! Do this in Track mode with Stabilitrak Competitive Mode enabled (CAREFULLY!). The automatic up-shifts feel lightning fast!
PnCRedJwl2SS
02-09-2019, 08:03 AM | #26 |
Drives: Camaro 2SS & ZL1 Join Date: Mar 2018
Want to slow down fast? Just put it in manual mode and hold the down shift paddle for over a second
2017 Camaro 2SS A8 Bright Yellow NPP MRC
2023 Camaro ZL1 A10 Radiant Red |
02-09-2019, 11:34 AM | #27 |
dp77
Drives: camaro Join Date: Apr 2018
I feel like everyone here has completely missed out on the question. Im not asking how to slow down USING the transmission.
Im asking if you slow down using the brakes, should you ALSO downshift, or just let it downshift for you? and any advantage/disadvantage? |
02-09-2019, 11:35 AM | #28 |
dp77
