09-13-2018, 10:26 AM | #1 |
Drives: 2017 SS 1LE Join Date: Sep 2018
Track alignment??
I’ve heard people talk about getting your Camaro track aligned.
Will any alignment place know what to do here for optimal track handling?? Say les Schwabor just the chevy dealership? I have a 17 SS 1le. Put new brake fluid in. Now to alignment. Then to track Thanks in advance Last edited by Jcvibby; 09-24-2018 at 04:18 PM. |
09-13-2018, 11:00 AM | #2 |
no most places you have to give them the track alginment specs otherwise they will just give you standard alignment
09-13-2018, 10:51 PM | #3 |
all it takes is cash
Drives: 2018 LS V6 1LE; E350 wagon; Model3 Join Date: Jan 2017
My experience at a Firestone Complete Auto Care was that despite giving the tech the Chevy specs and his explaining that he tried everything he could, he only got me 1 degree of negative camber on the front axle (not the 2 degrees recommended by Chevy for my car).
Then I went to what I think is the best local Chevy dealer in my area, and the tech there got the full 2 degrees. He explained a step that the Firestone guy probably didn't know or understand. Sorry I can't explain it any better than that. There are anecdotal stories of horrible jobs done at Chevy dealers, too. So the upshot is that when you want a track alignment, get your car to a technician who is experienced and knows your car. Good luck! |
09-15-2018, 07:24 PM | #4 |
09-15-2018, 07:51 PM | #5 |
09-16-2018, 12:54 PM | #6 |
Drives: 22' Porsche PDK GT4 Join Date: Mar 2018
I am having my alignment set to track settings on Tuesday.
What I am curious about , is how much of a difference it makes from the standard alignment as far as additional grip in the corners and how much sharper turn-in it gives you. Is it night/day or just a little more than normal.
Current:
22' Porsche PDK GT4 (MCS 2-way remote dampers) Previous: 18' NFG 2SS 1LE (ZL1 1LE solid rear cradle bushings & Corsa Exhaust) 16' F80 M3 (Ohlin R/T Coilovers) 13' Audi TTRS (APR Stage 1, MSS Springs) 09' C6 Z06 08' E90 M3 06' 335i (KW V2 Coilovers) 03' C5 Z06 |
09-17-2018, 11:08 AM | #7 |
on track its night and day but on streets probably wont notice anything except tire wear
09-17-2018, 11:16 AM | #8 |
Drives: 2018 1SS 1LE Join Date: Apr 2018
Haven't been to the track yet, but had a stock alignment up until about 3600 miles, now have a couple hundred miles with the track alignment. -2.4 front / -1.6 rear camber.
While not a scientific test, there's a cloverleaf on my way home that I know very well. With the stock alignment, around 50mph I would start getting some squeal from the tires. After getting the track settings, it's been solid 50-55 mph, no noise. It's noticeable, and well worth doing.
2018 1SS 1LE (sold) |
09-17-2018, 12:12 PM | #9 |
Drives: 2017 1SS 1LE Join Date: Jun 2016
I agree with the previous responses and say it's absolutely apparent on both the track and street. Your capability for lateral grip will be noticeably better in both spirited street driving and on the track. You'll also feel the road more (i.e. will have to fight pull on rutted pavement) with the camber being more negative, and will have a more "twitchy" on center steering response with the toe being closer to 0. I've been driving on it for about 1 yr which is about 6500 miles and 6 track days, and tire wear still seems relatively even with no complaints of driving it on the street. Both the inner and outer shoulders are getting pretty worn, so now I'm just waiting to see which shows cords first.
2017 SS 1LE.
09-17-2018, 04:27 PM | #10 | |
Drives: 2018 Camaro 1SS Join Date: Jun 2018
I might go try dealer next time.
2018 1SS 6MT: SOLD
09-17-2018, 04:38 PM | #11 | |
You may pay a little more, but a good quality alignment with someone who knows what they are doing will show in driving dynamics
Current:
09-17-2018, 04:39 PM | #12 |
True.
2018 1SS 6MT: SOLD
09-18-2018, 03:21 PM | #13 |
Track alignment done. You can feel the difference. There is more grip.
I noticed no tramplining and it tracks straight. Between the solid rear cradle bushings and the track alignment, I am very happy now.
Current:
09-18-2018, 09:31 PM | #14 | |
Drives: '16 2SS GD1 MX0 NPP F55 IO6 Join Date: Jun 2013
Weighted track alignment = best alignment. Place I go to charges 120$ each time I want to change my settings, but it is totally worth it. |
