01-12-2016, 07:14 AM | #1 |
Drives: 2015 Camaro 1LE Join Date: Feb 2015
Reverse lights come after shutting off.... ??
Has anyone experienced your reverse & tail lights coming on after you shut off the car? And then when you get out anr shut the door, the reverse and tail lights remain lit. I have to open the car door and shut it in the lights go out. I believe the lights are coming on before I even lock the door.
Its my '15 1LE with manual |
01-12-2016, 07:17 AM | #2 |
Drives: 2014 Chevy Camaro 1SS/RS Join Date: Oct 2013
It's exit lighting. To help you see. It's programmable in your MyLink menu settings.
Sent from my Nexus 6P using Tapatalk
2014 Chevy Camaro 1SS/RS L99
377rwhp/396rwtq Stainless Power 1-7/8 headers, HF cats Magnaflow 3" tru-x cat back exhaust NicKey Dyno tune Bo White ported throttle body Elite Engineering Catch Can CAI air intake GM Strut Brace Bar JL Audio 12w3 sub, JX1000/1d amp CFD Carbon Fiber pistol grip TapShift shifter EGX rear window louvers 4500k HID head and fog lights |
01-12-2016, 07:23 AM | #3 |
Yeah...but its the reverse lights too. I've never seen that on other cars that had that option... It wasn't doing it before either
01-12-2016, 07:26 AM | #4 |
Mine does it.
01-12-2016, 07:27 AM | #5 |
It turns off after a bit. It may only do it when the light sensor see's that it's dark enough.
01-12-2016, 07:37 AM | #6 |
Drives: 2015 Red Rock ZL1 Join Date: Dec 2014
You can program the lights how you want and it will sense whether or not the lights are needed. You can shut it all off and go ninja or turn them all on and be spotlighted...
Alex
2015 Red Rock ZL1 Panama City Beach, FL |
01-12-2016, 07:46 AM | #7 |
Drives: 2014 1SS/1LE Join Date: Nov 2015
Mine does it.
01-12-2016, 07:55 AM | #8 |
Drives: 2013 Camaro SS 1LE Join Date: Oct 2014
Mine does the same
01-12-2016, 08:29 AM | #9 |
Drives: 2013 Camaro 2SS RS LS3 Join Date: Feb 2011
Both my Camaro and Silverado do this. Completely normal.
-2013 Summit White over Inferno Orange 2SS RS- -2014 White Diamond Silverado Z71 Crew Cab Short Box- |
01-12-2016, 10:54 AM | #10 |
Drives: 2015 1SS RS Join Date: Aug 2014
just hit the unlock and lock button on the remote will turn it off
01-12-2016, 12:11 PM | #11 |
It's designed to give you a view of what's around your car at night.
