02-03-2021, 12:19 PM | #1 |
Drives: 2018 2ss 1le Join Date: Feb 2021
Aftermarket seat help
new to tracking my car and I am looking to sit a little tighter in my 1le, the car is used for hpde events and weekend driving it is not a daily driven car or a full track build.
eventually, I want to add the studio rsr harness bar and 4 point harnesses i really like what they did with the car in the pictures for the harness bar but that is not within the budget right now, id like to start with just the seats if possible. is it possible to use a seat like a Sparco r333 or a Sparco Evo xl with OEM seat belts? if someone can help me out and provide links to all the best necessary parts like a base mount and slider it would be greatly appreciated. |
02-03-2021, 12:29 PM | #2 |
ive been looking at a setup also but you dont want to run just seats or even fixed back seats with a harness bar you could do harness and harness bar with stock seats but if you do fixed back seats you want to do whole kit
02-03-2021, 01:39 PM | #3 | |
Drives: Camaro 1ss Join Date: Nov 2019
The biggest issue with this is the factory seat belt is connected to the factory seat so if you pull the seat for a bucket you will loose the factory belt. this is the base mount I used https://www.plantedtechnology.com/pr...pplication=281 If you are over 6feet tall or have a sunroof I highly recommend NOT to use a slider. but if you are under 6ft tall and you're looking at a Sparco seat. Sparco makes nice sliders as well. I personally went with the sparco Grid 2, Sparco side mounts and the planted base.
Follow me on IG for build thread! https://www.instagram.com/tracked_1ss/
YouTube: https://www.youtube.com/@Tracked_1ss FortuneAuto Coilovers! https://shop-fortune-auto.com/produc...ries-coilovers |
02-03-2021, 01:52 PM | #4 | |
awww i didnt know that pretty shitty lol im looking at a full setup next month
02-03-2021, 02:04 PM | #5 | |
thanks for the links - i thought i had seen aftermarket seats with the factory belt somewhere on this forum but i could be wrong |
02-03-2021, 03:01 PM | #6 |
02-04-2021, 11:32 PM | #7 |
Drives: 17 hyper blue 2SS M6 Join Date: Mar 2018
You absolutely can use the factory belts with aftermarket seats. I have both the 6 point harness and the factory belts in my car.
02-05-2021, 06:40 AM | #8 |
Do you have pictures on how you attached seat belt? I was positive that it bolted to the stock seat
02-05-2021, 09:08 AM | #9 | |
i am looking to do this with no air bag lights on or problems i have a 2ss, can you please provide me in detail how you did this |
02-05-2021, 09:12 AM | #10 | |
I bought seat wiring harnesses for both sides, 2 resistors for the airbags. Took the occupancy sensor and seat position sensor from the passenger seat to plug into the harness, and took the memory function control module from the driver's seat and plugged that in. |
02-05-2021, 09:13 AM | #11 |
Use the BK mount is one way to do it. I'm working on the details now
02-05-2021, 09:15 AM | #12 |
02-05-2021, 09:59 AM | #13 |
idk why I never thought of that lol
02-07-2021, 03:43 PM | #14 |
Thread Tools | |
