10-26-2017, 02:05 PM | #1 |
Bullet Performance test primary cat delete pipes.
I will let these go for 150.00 plus shipping. They will come wrapped and include the Big Daddies Garage Anti-CEL adapters.
Here is the Skinny. I bought these supposedly "lightly used" from Vengeance racing. They stated that they were for a 2016-2017 6th gen camaro. So I purchased them for 300.00. I bought header wrap kit 20.00 and the Anti-Cel adapters(30.00). So I have 350.00 into them. I went to install them and the slip fit connection on the driver side was not the correct Diameter. I should of returned them, instead I cut the slip off with a band saw and made a new slip connection. I have not welded it on. I used it as a adapter to slide the cat back and delete pipe together and clamped it. It works fine,... only removed them because I prefer the sound of the Stock NPP setup with fuse pulled. I already have another Camaro that is loud. I reduced the price due to the slip connection being modified. You could take it to a welding shop and have the slip welded on. Its not hacked up or anything. Here is a pic before I installed them. I will get a pic showing the modification I made.
2016 NFG 1SS A8
Options-2SS Leather/NPP Perf. mods-Whipple 2.9/Fuel System/Flex Fuel/103mm TB/Rotofab Big Gulp/Cat Deletes/Corsa NPP Per. times- 10.5 @ 137 w/ 1.8 60ft Full weight on 20's 1200DA Last edited by KingLT1; 10-28-2017 at 08:31 AM. |
10-27-2017, 05:31 PM | #2 |
Pics of modded slip. As you can see its not hacked up and its a tight fight. Fits right into the factory cat back on a SS like the OEM pipe.
2016 NFG 1SS A8
10-28-2017, 08:30 AM | #3 |
Price reduced...150.00 + shipping.
2016 NFG 1SS A8
10-28-2017, 11:44 AM | #4 |
Drives: 2016 Camaro 1SS (Dory) Join Date: Jun 2017
PM'D
10-28-2017, 01:36 PM | #5 |
Replied.
2016 NFG 1SS A8
10-28-2017, 01:54 PM | #6 |
Not trying to piss on your sale. But do those "no CEL" adapters really work? I was thinking about buying some for my car.
10-28-2017, 03:52 PM | #7 |
SOLD!
Yes
2016 NFG 1SS A8
10-29-2017, 09:44 PM | #8 |
Drives: 2017 Camaro 1SS A8 Join Date: Jan 2017
So mad I missed these!!! Let me know if for some reason they fall through!
