06-25-2013, 10:13 PM | #15 | |
V8 Lounge member #2
Drives: 2001 Ws6 Join Date: Sep 2009
It's different that's for sure. Now imagine a nawz fogger on that biach too? Hot damn!
2001 ws6, 40k miles, Ls3 416 stroker, short block built by PER the rest by me. LPE Ls3 heads milled to 12-1 comp, FAST 102, NW 102, kooks 2", dual DMH cutouts, Magnaflow C/B, BTR cam + springs. Full UMI suspension.
06-25-2013, 10:28 PM | #16 | |
Drives: 2010 aqua blue SS/RS M6 Join Date: Feb 2010
As far as why, carbs have come a long way for one, I have old school blood and I think this setup would be insain to see in a 10 camaro! Not only look sick as hell, will run like a raped ape too! How awesome would that engine setup, big cowl, and drag wheel tire setup be! The baddest mofo ever, that's what! Lol
10.91 at 122 H/C stock block N/A
06-25-2013, 11:12 PM | #17 |
Drives: 2012 Camaro 2SS/RS Join Date: Dec 2011
Ok it definitely would be different I'll give ya that, but for more horsepower just simply isn't true. They claim the carb manifold is a bolt on 25hp over stock injection but you need to read the fine print. The stock tune is safe and lazy compared to how the carb would be set up as well as the agressive msd box timing curve. Not to mention the numbers they claim are with headers. So add a set of headers and an agressive tune on the factory injection and you'll definitely have more than 25hp.
Sent from my Galaxy "LS3"
2012 Camaro 2SS/RS, Hurst Short Throw, IdealG M/C, Pypes Pipe Bomb, LSR Cold Air Intake, LSR Toe Links/Lower Control Arms Clear Image headers, high flows, Slowhawk tune
1974 Chevy K10 Built 355, FAST EZ EFI, 5speed 2000 Chevy Tahoe LT 5.3L, Slowhawk tune |
06-26-2013, 12:12 AM | #18 | |
Drives: 2012 45th Anniversary 2SS Join Date: Mar 2012
06-26-2013, 01:03 AM | #19 | |
Drives: 2010 Camaro 1SS/RS, 1973 Corvette Join Date: Dec 2011
I, personally, would not recommend going to a carb. The headaches you would go through to make it work would not be worth it. If you're going for nostalgia, I recommend getting rid of the car and purchasing a Gen 1. If you just want the look and possibly the added performance, I would follow litle88's advice. I'm sure you could purchase that Edelbrock manifold and the rest of the stuff from F.A.S.T. so that way you can keep your multi-port injection and reap the benefits of the looks and performance of the other style manifold. I can say for certain it will not be cheap. With that said, I would consider something more unique if I was going to invest in a new induction. Check out this by Inglese: http://www.compperformancegroupstore...de=BaseKitsXFI |
06-26-2013, 07:58 AM | #20 | |
06-26-2013, 08:33 AM | #21 |
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
To run carb need something like msd 6012.
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
06-26-2013, 08:35 AM | #22 |
It's been proven many times that a carb setup has the ability to make more power, if I go this route the car will be a toy and not a daily like now. Carbs are simple to work on and tune, with the right parts and a good carb this setup can be very reliable! Why would I buy an old car just to put the engine and trans in that car when I already have it!!! Also the money it would cost will really not be all that bad, probably under 2k to do this work and I would also get money back selling my ls3 efi! I seem some dyno test were this type of setup made ALLOT more too end power and torque!
06-26-2013, 08:42 AM | #23 |
HOZPOWA! Lmao, I like that one littl88! A bit of Dom Terreto lmao
06-26-2013, 08:55 AM | #24 |
Totally agree, I do have to say though if you are going for some high horsepower strip car Q-jet not that great, but I run a Q-Jet on my 406 solid roller engine in my S10 on the street as they have great manors around town. I do switch to a older Barry Grant King Demon when I run at strip though.
2011 SS/RS Homemade CAI, Doug Thorley Muffler Delete, Burns Stainless X-pipe and Dynomax Race Bullets, 8k HIDS and Fogs with harness, Tuned by Me on HPTuners Yes its quick...quicker then you think!!! |
06-26-2013, 09:29 AM | #25 |
Yep a BG is a nice carb, HP style with a nasty cam! This little 376 will scream, best thing about this idea... I would still have all the comfort of a 5th gen, but with a Nasty old school attitude!
06-26-2013, 12:15 PM | #26 | ||
Drives: 2012 45th Vert, 2011 4x4, 9sec Vega Join Date: Mar 2012
The only possible reason to ever go carb is for 1/4 mile use only. Block off all the other circuits and tune with the jets at WOT. Carburation is an inferior method of metering fuel . Period. They may have come a long way in mitigating the inherent problems of carburation but the very basis of how they function makes them inferior, period. Why? It relies on the velocity of air through the throttle body to pull fuel out of the venturies. And the velocity of air does not always equate to what the driver is trying to make the engine do, except at WOT and top RPM. You press on the gas pedal to go faster, you want to go faster but the first thing that happens is the throttle blades open and the vacuum dumps off to next to nil. It actually pulls less fuel than it was a second ago. You need an accelerator pump circuit at this point to keep the engine from just plain up and dying. Now the engine starts to speed up and the velocity increases. But the fuel supply is always behind the curve. That is why they get poorer economy too. You have to fatten them up because they are always behind. Even non electronic fuel injection is superior as fuel delivery is matched to engine speed and throttle position. It is squirted into the engine regardless of the velocity of air flow. Electronic is even better as it is capable of making many corrections based on air density, temperatures and current lean/rich conditions. Enabling peak economy and performance in all conditions. Do what you want OP. But don't get mad when I laugh at you
I feel it only fair to warn you, I have a black belt in CAPS LOCK.
06-26-2013, 12:40 PM | #27 |
Why would get mad, everyone has an opinion! I agree EFI is best for everything other then full throttle pulls. Go look around the web and you will find plenty test were the carb and intake setup made huge gains in RPM increase and power! I did not find a single dyno test were the stock EFI made more power! This is hot rodding bud, I think your just mad you didn't think of first lmao! I have a vision right now, all the old school cars are running new tech with these setups and have great success! Why not change it up a little and have something you don't see in a 5th gen...
The way I see it, why should I go back to old school rattle traps and crap suspension. Having to start from scratch, I will have everything I love in one car!
04-18-2014, 08:38 AM | #28 |
found this http://www.mastmotorsports.com/news-view.php?id=49
Ive been looking into a carb looking setup but efi thought it would be cool looks like im not the only one as far as efi vs carb both have their benefits and draw backs but IMO people have gotten lazy and dont even try tuning a carb.... if you cant tune a carb your not a hot rodder in my book also op....look up http://paceperformance.com/ for any carb intake manifolds for ls3
you rarely get second chances so keep the rubber on the asphalt
Last edited by 2manytickets_osofun; 04-18-2014 at 08:40 AM. Reason: forgot to spell check |
