Old 12-12-2019, 01:18 PM   #1
torakki SS
Drives: Chevy Camaro SS
SS Rear Spoiler - Custom Fabrication
I made a rear spoiler for our 2012 SS. I based it on a design I saw but a few little mods like a little taller to look a little more aggressive.
Started with a trip to Tap plastics to get some polymer. I sketched out a design, on my PG&E envelope (kinda like how John Lennon wrote songs) and transferred it out on the plastic. I used a smoked polymer for the center section to go with the Black theme of the rest of the car. Once I had it cut out, I set it on a bumper reinforcement, out of a Honda I was working on, that had a similar curve to the rear spoiler profile and used a heat gun on it with some hammers for weights to add some curve. It only added a little bit of the curve i needed, the rest was the flexibility of the polymer. I drilled holes in the stock spoiler and added riv-nuts to mount the new pieces. Then, painted the main piece with the correct base coat and sprayed a mat clear to finish it.
Then time to enjoy it. Went out to a cars and coffee and love the car.
One thing, once the mounting bolts got wet, they had surface rust. So, I sprayed them with the base coat and then some mat clear. Problem solved.
Thanks for reading.
torakki SS is offline   Reply With Quote
Old 12-12-2019, 02:26 PM   #2
Mr2Hard2See
Instagram: Mr2Hard2See
Mr2Hard2See's Avatar
Drives: 2011 2SS/ RS
Looks great
YOUTUBE CHANNEL: Mr2Hard2See
LSA blower BTR stg 2 cam 227/242
BTR dual springs pushrods lifters retainers etc
Che bronze trunnion Ls3 timing/valley cover
Dod/vvt delete Dsx e85 Dsx aux fuel pump Id1050x injectors ZL1 fuel pump, Griptech 2.55 pulley, Solo performance Mach ll 2.5 catback exhaust 1 7/8th Lt headers
Mr2Hard2See is offline   Reply With Quote
Old 12-12-2019, 06:47 PM   #3
Spec
Drives: 2010 Camaro 1SS LS3
Agreed. Looks great for the stocker spoiler...
Spec is offline   Reply With Quote
Old 12-12-2019, 07:48 PM   #4
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2017 Z06, 2019 XTS, 2013 SS
Wow, great job! I approve lol.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
TheFlyingBananaSS is offline   Reply With Quote
Old 12-13-2019, 08:34 AM   #5
kburlar
kburlar's Avatar
Drives: 2010 Camaro 2SS
Looks really nice. Do you have any pics looking at the front of the new addition where it butts up against the stock spoiler? Thanks.
2010 Camaro 2SS. Summit White.
1 7/8" 304 Dynatech Stainless Headers with High Flow Cats and Ceramic Coating,
Cold Air Inductions Intake System with Scoop, SCT X3 Programmer, Moroso Catch Can, Heater Hose Upgrade
3.91 Gears, Eaton TrueTrac Posi, Billet Main Caps, Ported Throttle Body
1LE Suspension. ZL1 Springs, 2.9L Whipple Ssupercharger
kburlar is offline   Reply With Quote
Old 12-13-2019, 12:46 PM   #6
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Paint the edges a complimentary cooler an will look really cool!!
Orange Krush II
1LE Front sway bar, Splitter, shocks and struts, Z28 dual mode mufflers, Intake, UCA Bushings, and Toresen 3.91 Diff. 1 piece DSS Drive Shaft, ZL1/C7 Calipers, and 32mm JPSS Rear Bar. ASC race spec splitter and wicker. 6th Gen M017 Wheels. Stainless Works 1 7/8 LTs. DSE and PAFDT Suspension components.
olblue75 is offline   Reply With Quote
Old 12-13-2019, 09:43 PM   #7
torakki SS
I'll take some photos of the front of it tomorrow. I can't find any close ups right now.
Interesting idea about painting the edges. What color you think would look good? The edges are probably the week areas since they're cut, filed then sanded to get as smooth as I could.
Thanks for all the comments....
Old 12-15-2019, 09:39 AM   #8
rdavis
Drives: 2012 SS
Looks really nice. Good job. Gives me some ideas since we have some similar material at my work.
2012 2SS/RS 6speed, Howards asa cam on 113lsa Stainless works LT's, NPP exhaust, Z28 Cai, 3.91 gears. Tuned by Blue Thunder 2 racing Lubbock Texas.
rdavis is offline   Reply With Quote
Old 12-16-2019, 06:14 AM   #9
jokrz187
jokrz187's Avatar
Drives: 2015 1SS
looks really good, nice work
Custom TSP Stage 2 Cam/GPI intake Ported Rod Mod /VARARAM CAI/Mishimoto Catch Can/1 LE front & rear sway bars/ engine cover/fuse box custom painted, strut tower brace, Texas Speed LT, Hi Flo Cats, Magnum Tru-X pipe, NGK Spark Plugs, PCM Spark Plug Wire, Painted Calipers, CF Spoiler w/wicker bill.
jokrz187 is offline   Reply With Quote
