10-30-2019, 10:03 AM | #1 |
Dyno Show Queen LOL
How do you feel about a 400 heat exchanger! Install and Review coming!
Dual pass thickness 2.20 inches
It's going to sale for around $400.00 and its about 2 months out I'll do an install and review as soon as the test exchanger shows up. It made me sick to think about dishing out 550(Ron Davis) 799.00 (ProSpeed), and even 1000 plus for W.X. and AFCO's. I'll keep ya posted about the H.E. my car will be done this week from the Port Injection modification and I plan on doing all the cooling mods myself like the Exchanger and Trunk tank installation so I'll be posting some good info again shortly.
Kong Ported 2650, Crawford Racing Port Injection, Weapon X 112mm Adapter, NW112mm TB, Livernois Ported LT4 Heads, Lingenfelter GT32 stealth cam, Haltech Elite, and Carbon by Trufiber Last edited by EDFHOBBIES; 02-06-2020 at 06:52 AM. |
10-30-2019, 10:54 AM | #2 |
Ah, gotta pull out my translation key again...
All in good fun. *joke* |
10-30-2019, 12:39 PM | #3 |
@viurniel
Drives: 19 ZLE A10, 15 2SS, 90 300ZXTT Join Date: May 2016
lol @Can'tHave2MuchHP
We can't deny that EDFHobbies is a mega contributor, he helps a lot of us... just need to read carefully. |
10-30-2019, 12:44 PM | #4 |
Bannable
I have read sooo many differing opinions on additional or larger heat exchangers. Consensus from a lot of the top dogs is that it only slightly delays heat buildup and then you will just be carrying around more hot water. I wish it was just cut and dry.
One must forego the self to attain total spiritual creaminess, and avoid the chewy chunks of degradation
2017 ZL1 A10 - Hyper Blue Metallic Rotofab CAI, TM ported TB, AWE non res touring catback with PLP's |
10-31-2019, 12:27 PM | #5 |
Dyno Show Queen LOL
I think your right but a high HP car needs it... also a larger tank and better pump will go a long way I plan on doing all 3..
01-14-2020, 06:42 AM | #6 |
Drives: 2017 Camaro SS 50th Anniversary Join Date: Jan 2018
Any updates on this $400 heat exchanger?? Where to buy. etc??
01-14-2020, 08:26 PM | #7 |
Dyno Show Queen LOL
Private Label Manufacturer or PLM should be done this week or next..
01-16-2020, 12:56 PM | #8 |
Dyno Show Queen LOL
Target price 395 dual pass to compete with AFCO
02-06-2020, 06:52 AM | #9 |
Dyno Show Queen LOL
Finally finished and will do a write up just got pics sent to me from manufacture.
02-06-2020, 10:53 AM | #10 |
Petro-sexual
NICE!!!
02-23-2020, 07:02 PM | #11 |
Dyno Show Queen LOL
Got the unit installed today a total of 2 1/2 hours...
Use the lethal video on how to remove front end I will not go over that part.. Next I removed black supports that go from radiator cover to bumper support. 10mm Remove the wire going across bumper support. Remove the bumper support 1 push pin in air duct and 4 bolts then lift up and pull out to gain 3 or 4 inches of clearance. Remove left and right side soft plastic shields around the headlights. 3 tree pins each Next use something to clamp hoses coming off exchanger then remove hose clamps and hoses. Next push/hold back plastic covers that hide the 4 bolts on either side of OEM exchanger and remove bolts Pull out old exchanger Install new exchanger in opposite order... In order to gain clearance between the heat exchanger and AC condenser I used half inch spacers (7/16 nuts) between the OEM bracket and tabs on new exchanger this left me with 3/8 clearance so the exchanger would not be rubbing the condenser. They have a thin Ron Davis style for 345 and a this one for 395. Sorian has data on OEM unit and when TX2K is over I'll take it back and we can see how much difference it adds. Parts needed: 4x 7/16 nuts 4x M6 x 30mm or 1.250 inches 4x 5/16 washers Double pass 2.25 inches thick Adds volume Looks great good welds Price is right! |
02-25-2020, 08:38 AM | #12 |
Drives: Chevrolet Camaro ZL1 1LE Join Date: Jun 2019
Good write up! Interested to see how much it actually helps. Definitely a lot of volume increase there.
02-25-2020, 11:01 AM | #13 |
Petro-sexual
Good Lord look how thick that thing is!!!
Looking forward to see what this baby does.
03-06-2020, 08:38 PM | #14 |
Dyno Show Queen LOL
I've had the exchanger on now for about 3 weeks and all is good. Ready to log as soon as T2k is over with. Great product at a even better price.
