Old 12-12-2016, 10:20 AM   #1
nounousomes
nounousomes's Avatar
Drives: Chevrolet Camaro 2017 LT/V6
Post Spare Tire Kit Compitability (2016/2017 Camaro LT/V6) RS with 20 inch Run Flat Set
Hi all,
I am totally new in here and new to the marvelous Camaros.
I am really disappointed that there are no Spare tires in there.
I did so digging, Chevrolet does not even offer a Spare Set for the 2016/2017s. I am totally fine with filling my Trunk with the Donut Spare tire (I travel alot).
So no, I need you help and suggestion,
Will the 18 inch Spare tire set from the 2015 Camaro work on my Car (RS 2017 LT with 20 inch Run Flat)?
Part numbers are here:
1)Wheel only (no tire) 18" part #:92230888
2) container #:92200810
3) strap #:25892541
4) extension #:25892542
5) jack kit #:92236233
I really need your experienced opinion.
nounousomes is offline   Reply With Quote
Old 12-12-2016, 10:27 AM   #2
Sledgehammer70
Lethal Camaro
Sledgehammer70's Avatar
Drives: 16 2SS, 71 Std, Suburban RTS
Originally Posted by nounousomes View Post
Hi all,
3) strap #:25892541
Lugs are the same so it should fit, but the car has run flats, so technically no spare is needed.
Sledgehammer70 is offline   Reply With Quote
Old 12-12-2016, 12:42 PM   #3
nounousomes
Thank you so much.
Sometimes I travel in rural areas for over 200 miles. I need to feel safe.
Any one actually did try this? Did it work? Any photos?
I am ready to buy it. Its something like $400, but I want to make sure it will work, otherwise I will be loosing my money. Also, I am not an expert. Just newbie in here.
Old 12-12-2016, 12:50 PM   #4
m666etal
Drives: Civic
Will a fix a flat kit work instead of a spare tire? I changed my run flats to A/S BFG's. Planning to buy a fix a flat kit. Will it work as intended with BFG's or similar A/S tires?
m666etal is offline   Reply With Quote
Old 12-12-2016, 02:10 PM   #5
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
Fix-A-Flat might be fine for small punctures but won't help in the situation where the tire is sliced by road debris or sustains other serious damage. Most run flats recommend that you only drive long enough to get to a tire shop to replace them. I'm not sure how well run flats work if the tire is badly damaged. In an extreme case without a spare you might be waiting for a tow truck.
Old 12-12-2016, 02:22 PM   #6
Hyper16
A Heartbeat Away.........
Hyper16's Avatar
I got a spare from Performance Spare https://performancespare.com/
Since I took off the run-flats I'd rather be able to drive slowly to a tire shop than have to have the car towed. JMO
The dealership gave me a fix-a-flat kit with the compressor, etc. but I don't trust it.
Old 12-12-2016, 02:24 PM   #7
Lukemo
Lukemo's Avatar
Drives: '17 1LT RS V6 6M NPP
Pretty sure fix a flat will damage your tire pressure sensors if you have them in your new tires
Lukemo is offline   Reply With Quote
Old 12-12-2016, 04:16 PM   #8
2slow95vert
Drives: 2016 2SS Hyper Blue
http://www.camaro6.com/forums/showthread.php?p=9363714
This is what I did. I think it's the best option without adding an actual spare tire. But if you did add one I think this is still beneficial.
2slow95vert is offline   Reply With Quote
Old 12-12-2016, 06:02 PM   #9
nounousomes
I am really into getting a spare tire while keeping my run flats.
Any one can confirm that this kit could work?
http://www.wholesalegmpartsonline.co.../19257799.html
Old 12-13-2016, 07:39 AM   #10
nounousomes
I would really appreciate it, as a new guy in the block, to get your expert opinion.
Old 12-25-2016, 07:17 AM   #11
ny tdi
ny tdi's Avatar
Drives: 2016 1LT V6 6MT Convertible
GenV and GenVI wheels are interchangable. The only concerns should be:
1) Brake clearance
2) Rear differential wear
I have a 2016 1LT RS, same as you. But I will be adding the the OEM Brembos soon. The GenV spare tire set won't clear the Brembos. Also, they have a smaller diameter than your 20's (despite the thicker side wall of the spare kit). That means that you shouldn't mount them in the rear, lest you risk damage to the diff. Unless you have an Automatic, in which case, there's no diff.
For me, I'll get the kit from performance spare (mentioned above). It's made to clear the Brembos upfront, but has a similar diameter to the RS wheels, so they won't stress my rear diff (I have a 6MT V6).
ny tdi is offline   Reply With Quote
Old 12-25-2016, 05:23 PM   #12
nfboy
Drives: 2017 Camaro 1LT HBM
1) Brake clearance
Don't all cars have a differential? It allows the wheels to rotate at different rates during a turn.
nfboy is offline   Reply With Quote
Old 10-27-2017, 04:48 PM   #13
italiano687
Drives: 2015 Chevrolet Camaro 1lt
Run Flat Worked
I can attest to the fact that the stick run flat is able to be. Driven after being badly damaged. Last week I hit a curb and split the. Run flat at the wheel and I was able to drive it 9 miles at about 55 miles per hour on a shitty road. I then got up the next morning and drove the car about 50 miles into the city to try and replace the tire. It held up at speeds of 45-55 on crappy roads in South Carolina. The downside was no one not even the dealer carried the tire and none could get it on a saturday. The only offering was a Potenza by Bridgestone. I hated the noise and the hard ride of the run flat so I replaced all the. Tires. I am in need of emergency solutions now also.
italiano687 is offline   Reply With Quote
Old 11-02-2017, 06:58 AM   #14
Yosh6
Yosh6's Avatar
Drives: 2024 Toyota Camry XSE
An option is Modern Spare, a company that makes cast aluminum wheels for newer cars that don't come with spares. They are on Ebay. Wheel, tire, jack, lug wrench kit, about $370 to your door.
https://www.ebay.com/itm/2016-2017-C...9ZXFKU&vxp=mtr
2016 1SS - Bought: 8/2017 Sold: 12/2023
Yosh6 is offline   Reply With Quote
spare tire kit
