05-22-2018, 09:27 PM | #1 |
Drives: 2017 1ss m6. Blue..... Join Date: Mar 2017
1le parts on 1ss non mrc? Waste of money?
I got a few questions regarding gm performace kits and 1le parts for my 1ss non mrc. The handling kit for the mrc comes with shock tower mounts and for my car just sway bars and the front control arms?? PN 84242386. I have BMR stuff on the rear and bmr lowering springs but my front end is stock. I will most likely do bmr sway bars, but what about the shock mounts and the front ride links and handlig links which seem to be different. Whats the difference between the 1le parts and SS . Fe3 vs fe4.
05-23-2018, 08:04 AM | #2 |
Drives: 2017 1SS 1LE Join Date: Jun 2016
84242386 is the front stabilizer bar, rear stabilizer bar, and front handling links that are stiffer than stock and designed to be used with the GM lowering kit. I don't know specifically which part numbers each part is, but I assume they're stiffer bars and bushings to handle the increased loads from the lowering kit. In general, the FE4 suspension is going to have stiffer bushing/rubber rates than the FE3 where there are different part numbers.
Take a look at the suspension part number megathread. It's a great breakdown of all the different components and part numbers. When you see different part numbers for FE3 vs. FE4, the FE4 part number should be the stiffer one.
2017 SS 1LE.
05-23-2018, 01:32 PM | #3 | |
05-25-2018, 06:45 AM | #4 | |
What's the end goal of the suspension changes you're making? That will determine if you want to get the handling links in addition to the changes you're already making.
2017 SS 1LE.
05-25-2018, 01:07 PM | #5 | |
Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
The FE4 rear links, which are not in that kit, just have stiffer bushings over the FE3. This is why GM has the front links in the kit and not the rears - the fronts are a significant improvement and the rears aren't as much. The rears are more of a fine tuning element to the 1LE/ZL1 package. |
