TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > Transmission / Driveline
Old 06-10-2018, 09:15 PM   #1
Juiced1
Drives: 2012 2SS CAMARO 45th
DRIVESHAFT SHOP AXLES/DRIVESHAFT ON SALE AT JUICED MOTORSPORTS
For the past 30 years, Driveshaft Shop designed many of the driveshafts used in numerous record setting racecars. They offer driveshafts in aluminum, steel, chromoly and now carbon fiber so they can design a solution that fits your needs. Each driveshaft they produce is dynamically balanced at over 9000 RPMs to ensure unbeatable reliability. Call for custom sizes for cars with swapped transmissions and rear end set ups
2010-15 SS M6 3.5" Aluminum Driveshaft
2010-15 SS M6 3.375" Carbon Fiber Driveshaft
2010-15 SS A6 3.5" Aluminum Driveshaft
2010-15 SS A6 3.375" Carbon Fiber Driveshaft
2012-15 ZL1 M6 3.5" Aluminum Driveshaft
2012-15 ZL1 M6 3.375" Carbon Fiber Driveshaft
2012-15 ZL1 A6 3.5" Aluminum Driveshaft
2012-15 ZL1 A6 3.375 Carbon Fiber Driveshaft
2010-15 SS Level 4 1000HP Bolt-In axles
2010-15 SS Level 5 1400HP Bolt-In axles
2010-15 SS W/Strange S60 rear end Level 5 axles
2012-15 ZL1 Level 5 1400HP Bolt-In axles
Juiced1 is offline   Reply With Quote
Old 06-26-2018, 05:27 PM   #2
Juiced1
Break records not your drivetrain
Old 07-08-2018, 07:26 PM   #3
Juiced1
Launch like you have no worries
Old 12-20-2018, 04:50 PM   #4
Juiced1
Break records not your axles
Old 01-18-2019, 06:15 PM   #5
Juiced1
Go ahead and turn up the boost
Old 02-17-2019, 05:00 PM   #6
Juiced1
BIg power..no problem
Old 03-08-2019, 06:31 PM   #7
Juiced1
Track warriors
Old 04-01-2019, 09:35 PM   #8
Juiced1
If you want to own the track you're gonna want some of these upgrades
Old 04-18-2019, 11:04 PM   #9
Juiced1
Carbon Fiber options
Old 05-10-2019, 07:40 PM   #10
Juiced1
Build it right
Old 06-05-2019, 11:27 PM   #11
Juiced1
For track warriors
Old 07-02-2019, 08:44 PM   #12
Juiced1
Launch with sticky tires and zero worries
Old 07-27-2019, 10:26 PM   #13
Juiced1
Once you add the power you'll need to beef up the drivetrain
Old 08-15-2019, 11:25 PM   #14
Juiced1
Big power cars should check this out
axles, carbon fiber, drivehshaft, driveshaft shop
