05-19-2022, 12:05 PM | #71 | |
Drives: HBM ZLE Join Date: Aug 2017
Great gains Tim! Can't wait to see you drop a cam in it! When the time comes. |
05-19-2022, 12:35 PM | #72 | |
Drives: 2019 ZL1 Join Date: Mar 2019
Should look like this.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
05-19-2022, 02:45 PM | #73 |
It's objectionable to many, but I've always believed that the valve train should be your first mod
'20 ZL1 1LE A10,
05-19-2022, 04:08 PM | #74 | |
Drives: 2019 Chevy Camaro ZL1 M6 Join Date: Jul 2019
Kong Stage X Port, NW103, LPE HPFP, XDI +30 Injectors, ARH Headers, Flex Fuel, JMS Booster, AWE Touring, Elite E2-X CC. Stock heads, stock cam, stock pulleys: Tuned by KingLT1. 740whp Uncorrected on e50
05-19-2022, 05:00 PM | #75 | |
Having FUN in the SUN...
Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
Great results... Im sure she pulls strong...
2022 M6 ZLE: Katech CNC Ported Blower + Ported Heads + 103mm TB + Oil Pump + C5R Chain + Valve Covers + Coil Relocation
TSP VVT and DoD Delete Covers + LME Chain Guide + DSX Billet Lid + ATI Damper + 9.17" Lower + 2.4" Upper + MM Wild CC Coated ARH + AWE Touring + Magnaflow Center X + E85 + MSD Coils + Banks iDash + JMS Booster + Synergy Fender Tank ALL the RED Rear End BMR Goodies + JRE Terminator Cam Package + Remote Tuning and Moral Support from TED @ JRE BMR Motor Mounts + DMS Front HX + FIC 30's + APEX SM.10's + 305/345 R888R's = 770rwhp 785rwtq @E50 13.5psi |
05-19-2022, 05:06 PM | #76 | |
Makes me wonder... If you are a bolt on car like me with 650rwhp, and you are thinking of more... sounds like there are (2) different directions to take to get to 725rwhp+ 1. Cam 2. Blower Porting + Fuel System Is it just me... or is the cam only the cheaper route right? You get the HP and fuel gains with one bullet? Or am I over simplifying it? I can see that option.2 has alot more room for future growth, but if 725rwhp +/- was the goal, that cam only would be the most cost effective?
05-19-2022, 06:00 PM | #77 | |
05-19-2022, 06:01 PM | #78 |
Yes sir. I put some miles on this afternoon. It pulls hard to redline. It’s quite a hoot to drive.
05-19-2022, 06:32 PM | #79 | |
'20 ZL1 1LE A10,
05-19-2022, 07:34 PM | #80 | ||
Swear I'm not trying to hijack the thread, hope this helps give a little knowledge |
05-19-2022, 08:11 PM | #81 | |
I’ll add that I was surprised just how easy it is to R&R the blower, HPFP and Injectors. Shops shouldn’t be charging more than 4 hrs to remove and 4 hrs to replace all 3 items at once. And that’s being very generous. Probably more like 3hrs/3hrs.
05-19-2022, 08:55 PM | #82 |
Here's the current SAE CF formula. All you need is pressure in mb and ambient temp C. The main point is, the formula is in Dyno Jet's computer.
'20 ZL1 1LE A10,
05-19-2022, 09:10 PM | #83 | |
A cam kit and install normally run 5k +. Setup 1 will be faster in real world...
2016 NFG 1SS A8
05-19-2022, 09:59 PM | #84 |
An added benefit to this build is that the blower whine is noticeably louder. I removed the sound dampening plate from the lid. That combined with the switch to the Big Gulp and the Kong porting really make a difference.
