04-13-2022, 03:32 PM | #15 |
Drives: 2024 Riverside Blue 2SS 1LE Join Date: Mar 2016
I track my 2016 LGX M6 RS. When I started a couple years ago I did a lot of research. I upgraded the JL9 Brake RPO code (single piston) with G Loc R10/R8 pads and kept stock rotors. Pads are expensive but well worth it. I use Castrol SRF fluid and do a complete flush on the first pad swap of the year. I swap pads and don't use track pads on the street they squeal and the brake dust is crazy. I also invested in stainless steel brake lines. I got rid of the run flats and bought Goodrich g-force comp 2 A/S, they held up ok. I never experienced any brake fade and pushed them hard. This year I invested in a set of SS staggered rims wrapped in Eagle F1 SC3 rubber to get better bite on turning and braking. The only disadvantage with the V6 is you don't have the power on long straights but overall it is an excellent car for tracking. Next year I might invest in coil overs. I was thinking about upgrading the front brakes with 4 piston Brembos but a little hesitant to pull the trigger cause you cannot upgrade the rear due to having different EBrake systems and the design of the brake system as a whole the car is well balanced and using the upgraded track pads does a good job. When buying rims for this year I was looking for 19s but I came across such a good deal on a set of 20"SS rims i couldn't pass on it. From research I think 19s work better for auto cross and corner off at the track. I do use 0w40 at the track and change after every two track days and after each session I check the dip stick and have never used oil, and I have never lost oil pressure in the corners so I would suggest not overfilling before track days and I have never seen GM recommend overfilling the LGX on track days only the 6.2. I also change the rear end fluid at the beginning of the year and the trans fluid. The M6 is easy to change. The only other disappointment is a safety harness, I would like to upgrade to a 4 point system but with our OEM seats you cannot loop a seatbelt over the top and no one makes a system for the Camaro unless you have a roll bar.
04-13-2022, 04:29 PM | #16 | |
Drives: Slow Corolla Join Date: Apr 2021
‘21 Satin Steel 1LT 1LE
Prior: '22 Camaro 1SS 1LE '90 Mustang LX '18 Volkswagen GTI |
04-13-2022, 05:10 PM | #17 | |
I like the way there’s several classes you could enter. So you’re thinking the 6 piston brake setup is worth the $3300 factory upgrade?
04-13-2022, 05:17 PM | #18 | |
Prior: '22 Camaro 1SS 1LE '90 Mustang LX '18 Volkswagen GTI Last edited by Paulman; 04-13-2022 at 08:59 PM. |
04-13-2022, 07:27 PM | #19 | ||
Drives: Chevrolet SS 1LE Join Date: Oct 2019
Matt Miller
2020 SS 1LE |
04-13-2022, 08:58 PM | #20 | |
The only info I can find is the V6 1LE doing very well with its 4 piston caliper setup at the Lightning Lap competition. Since the V6 is lighter I’m wondering if 6 piston calipers are overkill and add too much weight up front. This option would be financed into the price but it would be warrantied and save me some wrenching time.
04-14-2022, 09:21 AM | #21 | |||
Matt Miller
2020 SS 1LE |
04-14-2022, 02:06 PM | #22 | |
Since all of my cars for HPDE have been street driven and I don't have a truck and trailer, I've been using the "80% rule" for making sure I try not to keep up with faster cars and limit the car to 80% of flat out so I can get it home in one piece. I hear ya on being spoiled by what's out there now. I thought upgrading my Fox body Mustang to SN95 Cobra brakes was the best thing in the world until I woke up and tried something else. I guess it will come down to experimenting with things over the course of a few HPDE events. I think the V6 is a very capable setup from what everyone is saying.
04-14-2022, 02:48 PM | #23 |
Exactly the same for me. The way I say it is: "At track days I'm an 8/10s kind of guy."
Matt Miller
2020 SS 1LE |
04-14-2022, 03:34 PM | #24 |
Drives: Boost Coupe Stewie formerly '01 Z28 Join Date: Jan 2007
To give you an idea of what goes into a Street category SCCA autocross campaign, this thread (though for a 2.0T) gives lots of insight - https://www.camaro6.com/forums/showthread.php?t=477232
04-14-2022, 07:43 PM | #25 | |
04-15-2022, 04:59 AM | #26 |
I am in the exact same boat. I want a nice weekend mountain carver to mess around with and go to AutoX/track days with friends. Not daily. I daily my MK7 GTI.
I've been trying to get my hands on a V6 for a while now. Obviously I'm looking full time for a used 1le v6 but I also just gave another dealer (3rd dealer actually) my build summary. I also go back a fourth on break upgrades (4piston vs 6 piston). Honestly, for a V6 camaro staying below $34k is ideal. So configurating a build with the $3k break option eats up a lot of that budget. I tend to build my V6 like this: 1LT manual RS (you get the wheels that fit both break options) Dual exhaust 4piston breaks and oil cooler Front lip aero tech pk Swede interior $34,075 or 1LT V6 manual 6 piston break (fits with those ugly base wheels) but then get Apex Sm10's ($2500) Satin Black appearance package- you get a small rear lip and black mirrors Swade interior Tech Pk. $34,025 One opinion I do have to share- The breaking system on my 2019 STI was PHENOMINAL. We all tend to get caught up on handling, power, speed, accelerating, whatever, but experiencing a VERY good breaking system is also very cool. I'm constantly changing my mind...but its fun. lol |
04-15-2022, 10:49 AM | #27 | |
These are nice builds. I keep doing a build over and over too, trying to stay in a budget. The 6 piston brakes chew up the budget. I daily drove a GTI too for 3 years - my mistake was getting an the S trim with the single piston brakes and no LSD. I said I would never cheap out again on that if I want to put a car on the track. Maybe the 4 piston brakes (which are really SS brakes?) would be enough with good pads and fluid? Would an equivalent to Hawk HP Plus be enough for a V6? DPEVANS above mentioned a GLOC pad with single piston brakes and had success
04-15-2022, 01:44 PM | #28 | |
OTOH, if you want pad to do everything, it will always be a bit of a compromise. I'm kind of spoiled because my SS 1LE comes with a good do-it-all pad: the Ferodo DS2500. Maybe that's worth considering for the smaller brakes too, or maybe there's an even better choice out there. Hopefully some others can chime in.
Matt Miller
2020 SS 1LE |
