02-21-2022, 08:26 AM | #1 | |
GPI Sales Consultant
Quick video on 1 piece driveshafts
I recently have had a few different people ask some questions about 1 piece driveshafts and why we would recommend one. I was way overdue for some new content on my YouTube channel, so I figured a quick 1 minute video for 1 piece driveshafts was in order. Maybe this helps this group a bit.
GPI Max Package 2.0: Brodix BR7 heads/GPI porting, MAX3 cam, ST2116LSR, BSR Max Lift rockers, LS7 LSXR with 103mm TB, Vararam OTR, Mcleod RXT, G-Force/Strange 9" IRS setup with 4.63 gear. 551whp, 11.1@124mph.
Got a question about a GPI product? Feel free to shoot me a message! |
02-22-2022, 07:43 AM | #2 |
the amount of slack in the stock driveshaft is insane.
2014 Camaro SS L99, Ashen Grey w/Black Leather - Build thread - http://www.camaro5.com/forums/showthread.php?t=491561
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, RPM 5” CAI, Kooks Headers, Solo Cat Back, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP |
02-22-2022, 08:05 AM | #3 |
Anthony S
Drives: 2011 chevrolet camaro 2ss/rs Join Date: Apr 2021
Agreed
I just installed my new DSS one piece 3.5" driveshaft over the weekend. What a huge difference. All of my steering wheel shake is gone on the highway and the car feels more responsive and snappy. My car only as 39k miles on it and the center coupler on the 2 piece driveshaft gave out and the rubber boots crumbled when I pulled the shaft out. I would highly recommend anyone considering a one piece shaft to just do it!
Follow me on instagram @The_bald_eagle_machine
https://www.camaro5.com/forums/showthread.php?t=600181 Mods: Texas Speed 2 inch headers, high flow cats, and X-pipe. Custom mid-pipe, Borla Xr1 mufflers. Torqstorm Supercharger, 3.1" pulley, ZL1 fuel pump. MGW Shifter, Mcleod RST clutch, Tick master cylinder and Tick Billet bushing reinforced slave cylinder. DSS One-piece 3.5" Driveshaft, Metco Driveshaft safety loop, BCRacing Coilovers. BMR Poly Diff bushings, Poly Rear cradle bushings, Sub-frame connectors, Lower control arms, camber arms, and toe links. |
03-14-2022, 09:08 AM | #4 |
Drives: 2013 Caprice PPV 2014 Caprice PPV Join Date: Mar 2022
My "Camaro" is a 2014 Chevy (Holden) Caprice PPV. The guys at The Driveshaft Shop in N.C. gave me all the info I needed for them to make me a carbon fiber DS. They said I could get most of what I wanted with their aluminum one but at ~600 ft lbs torque from the LSX from The Hot Rod Company of Green Acres (really) Washington, US the OEM or any two-piece was a really bad idea. Honestly the CF DS is better than I even imagined. While it's fairly long because it's for a Caprice, it does everything well. I recommend them.
04-20-2022, 05:43 PM | #5 | ||
05-11-2022, 10:19 AM | #6 | |
05-11-2022, 12:12 PM | #7 | |
I'm not sure your shifting question was directed to me, but it didn't change anything about daily driving shifting. Under full power it's a benefit because it's one less item flexing around in the driveline, and keeps everything more direct for the transmission.
05-11-2022, 12:40 PM | #8 |
not afraid of the wall
Drives: Camaros Join Date: Apr 2010
Definitely on my list for this winter along with a truetrac. Good stuff as always acammer
2023 1LE 1SS BCD GCF JF5 MN6 SIA SLN UQT
10/13/22: 1100 Past Camaros: 13 1LE|02 SS|01 Z28|00 SS|91 1LE|91 Z28|89 IROC-Z |
05-14-2022, 06:35 AM | #9 |
Drives: 2012 Camaro SS Join Date: Dec 2019
Can you post a video link. I can’t get the video to work
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
05-16-2022, 05:29 AM | #10 |
Give this a try: https://youtu.be/Do12rtaDizY
