05-12-2016, 05:14 PM | #15 |
Drives: 2016 Camaro 2SS 6SP/Suby Legacy 6 Join Date: Oct 2015
I just had to tighten mine for the 3rd time. Might have to use teflon tape if they loosen up again. They should have used metal fittings!
TFPK40
Its Here! Finally came home on 3-31-16! Red Hot 2SS,6 Speed, NPP, MRC, Adrenaline Red interior, Silver Rally Stripes, NAV, Sunroof, 56W Split Spoke Wheels, Body color Hood vents, Body color Splash Guards and winter protection package. Ordered 1-28-16: 1100 2-11-2016 :2000 2-15-2016: 3000 TPW of 3/7...That went quick! 2-26-2016: 3400 Status TPW 3/7 3-5-2016 : 3800 3-8-2016 : 4300 3-11-2016 : 4B00 3-15-2016 : 4200 3-22-2016 : 4800 3-29-2016 : 6000! |
05-12-2016, 06:07 PM | #16 | |
Drives: Blown up '16 SS Join Date: Nov 2015
Teflon tape on the fittings is totally overkill, but whatever you helps you sleep at night. Unless you can see oil leaking from the ports, stop freaking out about them not being 100% tightened . I tightened mine once after 2,000mi, and again after another 2,000mi (no oil was leaking from the ports, the fittings were just a little loose). The last 1,000mi I've done they have not loosened at all. I'm sure Mishimoto had their reasons for not using metal fittings, they don't seem like the type of company to flippantly make decisions on design items..... |
05-13-2016, 06:21 AM | #17 | |
TFPK40
05-13-2016, 07:43 AM | #18 |
Drives: 2016 Camaro SS Join Date: Jan 2016
Drive the fittings all the way in.
05-13-2016, 07:56 AM | #19 | |
2016 2SS 6-Speed Manual... Magnetic Ride Control, Dual Mode Exhaust, Sunroof, Adrenaline Red Interior, Mylink W/Navigation
Added Edelbrock E-Force Supercharger, GM 1LE Sway Bars, BMR Upper/Lower Trailing Arms, BMR Upper Control Arms. BMR Front/Rear Chassis Braces, BMR Tunnel Brace. GM Red knee Pads, GM Black Front Splitter, GM SEMA Concept Grille, GM Dark Taillights, GM Ground Effects package... Savini Di Forza BM-14 Gloss Black Wheels 9's front, 10's rear. |
05-13-2016, 10:52 AM | #20 |
Things left loose on a airplane end very badly!
TFPK40
05-13-2016, 11:45 AM | #21 |
LOL I am just as OCD as the next guy, and I completely understand the aircraft mechanic viewpoint, I'm just saying in this particular application, there is no need to freak out, just snug them up a couple times after a few heat cycles and a few thousand miles of vibration and you're probably good for life. Like TSloper said, ultimately the fittings should be driven in completely flush.
Has anyone here actually had oil leaking out of their in/out ports yet upon discovering loose fittings? |
05-13-2016, 01:42 PM | #22 | |
05-14-2016, 03:06 AM | #23 |
Drives: 2016 Camaro 2SS Join Date: Mar 2016
Any leaks would be unmetered air. I had to tighten mine twice and on the 3rd and final time I sunk them all the way in and they have not loosened again.
2016 Hyper Blue 2SS A8,NPP,Moonroof
Pray ported factory intake manifold Ported TB Rotofab ARH 1 7/8 longtubes hi flow cats AFM deleted E85 11.0@124.9 11.65@118.8 pump gas,stock tune/exhaust New combo: Pray Performance Heads/cam MSD intake manifold and Circle D 3C 554/491 on E85 all work & tuning done by Pray |
05-15-2016, 09:51 AM | #24 |
after 1500 miles I had about 1/8 of an inch of oil in mine. I'll be checking it reguraly.
05-16-2016, 10:56 AM | #25 |
I've checked it every 1500mi three times now, always about the same amount of oil, so i'm confident that that check interval can be doubled to 3000mi before the oil is hitting the baffle, unless you're hitting up the track everyday....
