04-23-2016, 05:49 PM | #1 |
Be sure to check your Mishimoto catch can.
Hey guys, if you haven't checked your Mishimoto catch can since installing it be sure to have a look at it.
Several people have noticed that the nipples that thread into the can needed to be tightened. This was the case with mine as well. They were tight when I installed it, but I guess that after a few heat cycles they loosen up. Pull the hoses off and you'll notice that they are super loose. A 17mm box end wrench will do the trick without pulling the can out.
2016 2SS 6-Speed Manual... Magnetic Ride Control, Dual Mode Exhaust, Sunroof, Adrenaline Red Interior, Mylink W/Navigation
Added Edelbrock E-Force Supercharger, GM 1LE Sway Bars, BMR Upper/Lower Trailing Arms, BMR Upper Control Arms. BMR Front/Rear Chassis Braces, BMR Tunnel Brace. GM Red knee Pads, GM Black Front Splitter, GM SEMA Concept Grille, GM Dark Taillights, GM Ground Effects package... Savini Di Forza BM-14 Gloss Black Wheels 9's front, 10's rear. |
04-23-2016, 06:29 PM | #2 |
Drives: 2016 Camaro 2SS 6SP/Suby Legacy 6 Join Date: Oct 2015
I had to tighten mine twice so far. I would rather not crank down on them. Just checked them today and they seem to be good.
TFPK40
Its Here! Finally came home on 3-31-16! Red Hot 2SS,6 Speed, NPP, MRC, Adrenaline Red interior, Silver Rally Stripes, NAV, Sunroof, 56W Split Spoke Wheels, Body color Hood vents, Body color Splash Guards and winter protection package. Ordered 1-28-16: 1100 2-11-2016 :2000 2-15-2016: 3000 TPW of 3/7...That went quick! 2-26-2016: 3400 Status TPW 3/7 3-5-2016 : 3800 3-8-2016 : 4300 3-11-2016 : 4B00 3-15-2016 : 4200 3-22-2016 : 4800 3-29-2016 : 6000! |
04-23-2016, 10:45 PM | #3 |
Drives: 2016 CAMARO SS2 Join Date: Aug 2015
I also found the connectors to the can to be loose. When I got the can Inwas surprised about the plastic. I wrote to Mishimoto remarking about it and never got a response. I bought a can for my wife's car at 1/3 the price and they were made out of chrome plated metal. They remain tight.
04-23-2016, 11:07 PM | #4 |
Drives: 2016 Camaro 2SS Join Date: Mar 2016
I tightened mine twice and the 3rd time I sunk them in pretty deep and they seem good now
2016 Hyper Blue 2SS A8,NPP,Moonroof
Pray ported factory intake manifold Ported TB Rotofab ARH 1 7/8 longtubes hi flow cats AFM deleted E85 11.0@124.9 11.65@118.8 pump gas,stock tune/exhaust New combo: Pray Performance Heads/cam MSD intake manifold and Circle D 3C 554/491 on E85 all work & tuning done by Pray |
04-25-2016, 06:44 AM | #5 |
Drives: 2016 Summit White 2SS Join Date: Jan 2016
Mine have went loose twice also almost seems like some Teflon tape would of helped but I don't know about the heat with it so I just keep tightening them soon be no thread left.
2003 Cadillac CTS Sold
2006 Nissan 350Z Sold 2008 Cobalt SS/TC Sold 2016 Camaro 2SS Summit built 3/28/16 delivered 2018 Camaro ZL1 cancelled by GM 😡 2019 Corvette 2lt Z51 |
04-25-2016, 01:30 PM | #6 |
Drives: 16 Camaro, 11 Stryker, 00 Explorer Join Date: Dec 2015
I was nervous about over tightening mine when I installed it. When I went to empty it after around 1000 miles, the plastic nipples were very loose. I cranked them down until the threads are hidden this time.
NGM, 2SS, 6MT, NPP, MRC, Nav, Kalahari, Grey Wheels
1100 12/14/2015 3000 1/8/2016 (TPW 2/1) 3800 2/1/2016 5000 3/5/2016 |
04-25-2016, 02:14 PM | #7 |
Drives: Blown up '16 SS Join Date: Nov 2015
Ditto, it didn't seem like they wanted to go all the way in the can when I first installed, now they're tightened down all the way to the hilt against the can....
04-26-2016, 07:18 AM | #8 |
Tightening them twice seems to have done the trick.
TFPK40
04-26-2016, 07:53 AM | #9 | |
Nightfall Gray Blackout
Drives: 2016 Camaro 2SS Join Date: May 2012
I check mine and it's loose as well. I wonder why mishimoto put a plastic not alloy nipple on this. |
04-26-2016, 12:26 PM | #10 | |
Just my guess. Otherwise.....cost savings.... |
05-12-2016, 09:56 AM | #11 |
Drives: Camaro 2SS Join Date: Feb 2016
Just randomly decided to check mine as well and they were super loose. Had to
Tighten them. Will be keeping an eye out for them losening up some more. |
05-12-2016, 11:24 AM | #12 |
Owning SSes for 50 Years
You got me wondering now. I noticed a strange sound coming from the area of the catch can and now wonder if it might be losing vacuum at the nipples. I am away from my car on vacation for a week, but gonna check it as soon as I get home.
The new ride: 2023 Camaro, LT1, Sharkskin Grey
Previous Performance Cars: 1966 Chevelle SS 4M, 2010 Corvette 6M 1968 Dodge Charger R/T Auto 2012 1SS 6M 1982 Corvette Auto 2010 1SS 6A 1984 Corvette Auto 2016 2SS 8A 1999 Camaro Auto 2017 HBM 1SS 1le 2002 C5 Corvette 6M 2018 2SS 2006 Corvette Auto 2023 Camaro LT1 |
05-12-2016, 12:26 PM | #13 |
Contacted Mishimoto about the issue. They said it was ok to use teflon tape and if that did not work, use oil compatible thread locker
05-12-2016, 01:57 PM | #14 |
Thanks!. I'll do that if needed, as I am now threaded in as far as the fitting will go.
